Swapping From Automatic To Manual Locking Hubs
By: Chris Emmons
1983-1997 Ford Ranger automatic locking hub
Take the wheel off first!………. Duh! Then pull the clips off the wheel studs.
1983-1997 Ford Ranger automatic locking hub removed
Pull the hub off and look at the inside of the old hub. It should be greasy, if not you will have troubles when you get deeper!
1983-1997 Ford Ranger automatic locking hub - remove c-clip
Next thing is the c-clip or “jezeus” clip (as in what you say when it goes flying!). A pair of old c-clip pliers did the job, sort of, by getting some out, and carefully prying.
1983-1997 Ford Ranger automatic locking hub - c-clip removed
Here’s the clip, about where it goes
1983-1997 Ford Ranger automatic locking hub - Remove toothed washer and automatic cam
You can pull the toothed washer, and also the old automatic cam off. Keep the washer, and put the cam with the old hubs. You wont use it.
1983-1997 Ford Ranger automatic locking hub - Remove locking nut
You should be able to rotate the big nut with a proper socket (ours was already loose!) and then take a strong magnet to pull the little wedge out. DON’T try to crank the nut off without doing this! you may never get it out!
1983-1997 Ford Ranger automatic locking hub - remove wedge
Here’s a closer look at the wedge
1983-1997 Ford Ranger automatic locking hub - remove spindle nut
Take the outer spindle nut off all the way,
1983-1997 Ford Ranger automatic locking hub - install new spindle locknut
Repack the bearings (if desired) and install then new nut (w/pin, facing out) from the conversion nut package.
(btw, these are just std manual hub nuts with a locking pin washer) Nothing special, cheap too.
1983-1997 Ford Ranger automatic locking hub - torque locknut
First torque to 35 ft lbs, while rotating. This seats the bearing
1983-1997 Ford Ranger automatic locking hub - rotate back 90 degrees
Then rotate back 90º (1/4 turn) and torque to 16 INCH lbs (fords factory setting) or whatever takes the slop out of the hub. I like mine a little tighter, it ends up being a 1/4 turn or so sometimes. With larger tires, 16 in lbs may not cut it.
1983-1997 Ford Ranger automatic locking hub - install lock washer
After you get it set, install the locking washer, so that the pin fits in one of the holes. If you cant get it in, flip the washer, and it usually will go.
1983-1997 Ford Ranger automatic locking hub - install outer lock nut
Next the outer locknut goes on, and it gets torqued to 150 ft-lbs
1983-1997 Ford Ranger automatic locking hub - Install toothed washer
Now, install the toothed washer on the shaft, past the ring groove in the axle. You may have to pull the axle shaft out by hand to get it all the way on.
(My Bronco II had a thrust bearing and a washer, the Dana 35 in the Ranger shown did not)
1983-1997 Ford Ranger automatic locking hub - install c-clip
Now install the c-clip, very carefully!
1983-1997 Ford Ranger automatic locking hub - install locking hub
Look at your pretty new hub. Lightly grease the innards to prevent corrosion, but don’t fill the bottom. Too much grease in the cap will prevent it from locking.
finished!
Install the cap, and Voila! your done!
Notes:
This comment was added by Bronc from our forum:
I just recently swapped my Dana 35 over to the Jeep manual hubs. All went well and was fairly easy, following the few write-ups in the tech pages. One thing I thought I would point out is how to remove the little wedge. It says to use a magnet to pull it out. That worked for one side, but the other was stuck in there. After a lot of screwing around, I decided to drive it through and if it ruined the bearing then fine. After I did that, I removed the spindle nut and found that the channel the wedge is in goes back further and is designed to have the wedge driven through to remove the nut. Then the wedge can be removed easily once the nut is off. Much easier than fooling around with a magnet.
Related Articles
1983-2011 Ford Ranger 4×4 Locking Hubs
Hub Troubleshooting
Automatic to Manual Hub Swap
Ranger Manual Hub Swap
Automatic To Manual Hub Conversion
Warn Jeep Hub Swap For Dana 35’s
AVM Xtreme Performance Hubs For The Dana 35
BlackBII’s Dana 35 Spindle Nut Mod
Dana 35 Jeep Locknut Upgrade
Warn Dana 35 Locknut Conversion
Manual Hub Bearing Replacement
Securing Your Hubs To The Rotors
Ford Ranger Spindle Nut Tool / Socket
About The Author
