Welcome
This page serves as a centralized index of technical articles, specifications, diagrams, maintenance guides, and modification resources for the current-generation Ford Ranger, including FX4, Tremor, and Ranger Raptor models.
Whether you are performing routine maintenance, researching factory specifications, troubleshooting issues, or planning suspension, tire, electrical, or off-road upgrades, this library links directly to in-depth, hands-on technical articles written specifically for 2019–2025 Ford Ranger owners.
All articles linked below focus on 2019–2025 North American Ford Rangers. If you are looking for technical information on earlier Rangers, please use the link below to access our 1983–2011 Ford Ranger Tech Library.
Disclaimer
Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities, it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
Engine & Transmission:
2019 Ford Ranger 2.3L EcoBoost Engine Introduction
2019-2024 Ford Ranger 2.3L EcoBoost Engine Specifications
2025 Ford Ranger 2.3L EcoBoost Engine Specifications
2024 Ford Ranger 2.7L EcoBoost Engine Specifications
Ranger Raptor 3.0L EcoBoost Engine
2.3L Ecoboost Ignition Coil & Spark Plug Removal & Installation
Ford’s Spark Plug Inspection Guide
Ford TSB 23-2011 Water In Spark Plugs
How To Keep Water Out Of Your Spark Pugs
2019 Ford Ranger Oil Change
2019 Ford Ranger Oil Change Instructions From Ford
Motivx 1/4 Turn Oil Fill Funnel For Your Ranger
Installing A START-X Remote Starter Kit
Transmission:
Ford 10R80 10-Speed Automatic Transmission
Ford 10R80 Automatic Transmission Assembly (.pdf)
Transfer Case & Terrain Management:
2019 Ford Ranger Trail Control & Terrain Management Explained
Adding Terrain Management To Your 2019-2023 Ford Ranger 4×4
Driveshafts
Rzeppa Joints (Front & Rear Driveshafts)
Axles:
Dana Spicer Advantek Axles In Your Ranger
Dana M220 Rear Axle Fluid Change Instructions
Dana M220 Rear Axle Fluid Check
Dana M190 Front Axle Fluid Change Instructions
Dana M190 Front Wheel Hub Bearing Removal & Installation
2019 & Newer Ford Ranger Axle Codes
Suspension:
3.5-Inch Suspension Kit Buyers Guide
6-Inch Suspension Lift Buyers Guide
2019 Ford Ranger Ride Height / Camber / Caster Specifications
Ford Ranger Camber And Caster Adjustment
Front Shock & Spring (Coilover) Removal & Installation
Why Isn’t My Strut Spacer The Size Of My Lift?
Installing A Skyjacker 3.5-Inch Lift Kit
Rough Country Leveling Kit Install on a 2019 Ford Ranger
Rough Country Leveling Kit – 2019 Ford Ranger 4×4 – Install
Belltech 25021 Lowering Strut Instructions
Belltech 6530 / 6531 Rear Axle Flip Kit
Install Readylift Anti-Intrusion Beams For Tire Clearance
2019-2023 Ford Ranger Sway Bar Link Upgrade
Tires & Wheels:
Largest Tire on A 2019 Ford Ranger Without A Lift
How To Choose An Off-Road Tire
2019 & Newer Ford Ranger Wheel Guide
2021+ Ford Bronco Wheels On A 2019+ Ford Ranger
Change Tire Size With FORScan
Tire Size Calculator & Size Chart
Introduction:
Introduction: 2019 Ford Ranger
2019 Ford Ranger Features List (.pdf)
2019 Ford Ranger Accessories List
2019-2023 Ford Ranger Off-Road Builders Guide
Technical Specs:
2019 Ford Ranger Body Builders Layout Book (Dimensions)
What’s The Difference Between The Ford Ranger Tremor & FX4
2019 Ford Ranger Specifications
2019 Ford Ranger Technical Specifications (.pdf)
Ford Ranger Maintenance Schedule & Fluid Specifications
2019 Ranger vs 2011 Ranger Size Comparison Chart
Diagrams:
2019+ Ford Ranger Instrument Cluster Diagrams
2019+ Ford Ranger Connector & Component Location Views
Programming:
Using FORScan on Your 2019 & Newer Ford Ranger
Make Driving Lights Stay On With High Beams (Bambi Mode)
Change The Radio Splash Screen With FORScan
Stereo, Radios & Navigation:
Ford Ranger Stereo / Navigation Screen Freezes
GMRS Dash Install 2023 Ford Ranger
Body & Exterior Upgrades:
How To Remove The Front Bumper On A 2019-2023 Ranger
2019-2023 Ford Ranger Grill Removal
ShrockWorks Rock Sliders
Ford Ranger DeeZee Tailgate Assist
Integrated Box Step Install
2021 Ranger ARB Snorkel Install
ARB 2019-2023 Ranger Snorkel Instructions (.pdf)
Electrical Upgrades:
Adding An Auxiliary Battery To A 2019+ Ford Ranger
Adding a 12V Power Point To Your Bed (2019-2023 Ranger)
2021-2023 Ford Ranger Tremor Auxiliary Switches Wiring
AOB 2019-2023 Ford Ranger Switch Panel Install
2024 Ford Ranger Raptor Auxiliary Switches Wiring
Mounting LED Off-Road Lights To Your Hood (Ditch Lights)
Upgrading A 2021 Ford Ranger To LED Light Bulbs
Ford Performance:
Performance Tune To 315 Horsepower
Ford Ranger Adds (3) New Accessory Packages
Ready Your Ranger With These Ford Products
Ford Performance Offroad Leveling Kit
Towing:
RedArc Tow-Pro Liberty Brake Controller
About The Author
