Introduction
This Suspension Tech Library is a centralized resource for Ford Ranger suspension design, modification, repair, and tuning. It brings together in-depth technical articles, installation guides, factory specifications, calculators, and real-world build examples covering everything from stock suspension maintenance to advanced off-road and fabrication-based upgrades.
The content on this page applies primarily to 1983–2011 Ford Rangers, including 2WD and 4×4 models with TTB (Twin Traction Beam), IFS, and leaf-spring rear suspensions. You’ll also find relevant information for Bronco II and Explorer-based suspension swaps commonly used on Rangers.
Whether you are leveling your truck, installing a lift kit, increasing wheel travel, tuning spring rates, or designing custom suspension components, this library is designed to help you understand how the Ranger suspension works—and how to modify it correctly.
Use the sections below to navigate suspension guides by generation, drivetrain, component type, and modification style.
Disclaimer: Information provided for reference only. Vehicle modifications may be hazardous. Read full legal notice.
2019-Present Ford Ranger Tech:
If you’re looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Information
- Stock Specifications
- 1983-2011 Ford Ranger Builders Guide
- How To Build A Ford Ranger For Overlanding
- Ford Ranger Off-Road Product Guide
- Ford Ranger Owners Manuals
Lift Laws
Solid Front Axle Swaps (SAS)
NOTE: Dana 44 front axle swaps / Solid Axle Swap (SAS) are in the Axles Section.
About The Author
Jim Oaks is the founder of The Ranger Station (TRS), one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and overlanding routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road adventures. TRS has been heavily referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information.
