I’ve found that motorcraft batteries are cheaper then any of the parts store brands.
I’ve got one that’s over 7 years old.
I ran a set of Eibach wheel adapters and ‘99 Cobra wheels on my lowered ‘90 Supercab. I would throw that truck into a cloverleaf at 80+ all the time… to the point that it would stall from fuel starvation if I was under 1/2 a tank. Those took a beating for way over 100K miles without any issues.I won’t be off-roading with the spacers, but I will be tearing up the roads. I like railing around bends. I don’t want something that is going to spit a wheel off because I took a bend too hard for it. That would likely be rather bad. Part of me questions as to if it would be smarter just to get aftermarket 18” rims and skip the spacers and factory rims…
That sounds like pretty solid quality. I’ll have to look into those. @4x4junkie gave me a couple other recommendations in the wheel spacer thread. I’ll pick something out. Just a matter of coming up with the extra moneyI ran a set of Eibach wheel adapters and ‘99 Cobra wheels on my lowered ‘90 Supercab. I would throw that truck into a cloverleaf at 80+ all the time… to the point that it would stall from fuel starvation if I was under 1/2 a tank. Those took a beating for way over 100K miles without any issues.
I would trust a good set, properly installed in any conditions.
31x10.50-15 tires are too squishy on hard cornering. My suspension isn’t fully squared away yet, but it’s good enough that you can feel the tire squish and it doesn’t feel comfortable at all. I need bigger rims and less sidewall to eliminate as much of the squish as possible. I’m looking at 255/55-18 or 255/60-18 for rims/tires at this point. On an 8” wide rim. I’m after stability. And yes, that does not absorb forces so much but passes them on, which is why I need something of decent qualityJust a thought, not from product knowledge, but from experience, and a little understanding of the math and geometry and loads.
Everything except my F250 runs on a 15 inch rim, with the old-fashioned “balloon“ tires. The Mark V weighs as much as the F250 and the town cars aren’t exactly lightweight. And you know my Rangers.
I would think the “balloon“ tires would take up a lot of the lateral forces on the wheels, spacers and bearings. Maybe not take up all the force, but certainly mellow out the high points and shock loads. I don’t think a properly installed spacer would fail from constant lateral loading, but rather an instant shock like if you hit a pothole on a curve. Byes/no?
I would think a taller wheel with less rubber would be more likely to fail from railing around turns. Yes/no?
Like usual, my two cents, I don’t know what I’m talking about, all food for thought…
Actually a 20-22” rim and a 28-29” tire would be a better combination, but anything over 18” would start to attract more attention that something is out of the ordinary and that starts to work against the whole “sleeper” aspect…Duh, Silly me. I forgot that you guys run tractor tires on your truck!
I was thinking of the guys who run the 22” inch wheels On the 26” OD tires on their 85 Impalas….
I love the 5.0 and how it sounds… but part of me is wishing I would have done as @bobbywalter recommended which was do a 3.5 EcoBoost with a 10-speed auto…
I’ve found that motorcraft batteries are cheaper the. Any of the parts store brands.
I would think the “balloon“ tires would take up a lot of the lateral forces on the wheels, spacers and bearings. Maybe not take up all the force, but certainly mellow out the high points and shock loads. I don’t think a properly installed spacer would fail from constant lateral loading, but rather an instant shock like if you hit a pothole on a curve. Yes/no?
While I can follow the logic there @Rick W, I think the idea is to reduce the softness of the tires and move those forces to the suspension which is much easier to control with springs and shock valves.
Can't really speak for lil_Blue_Ford even though we have similar goals, but that's where I'm heading with mine. Reduced sidewalls resulting in less deflection under cornering. It will reduce the ride but intend to improve suspension to compensate for that. There's not a lot that can be done with torsion bars to improve control, but once I have ride height sorted where I want it, I intend to do a coil over conversion. I'll spend time with those companies figuring out what would be good spring and valving for my intended usage.
