DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
2019-Present Ford Ranger Tech:
If you’re looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Catalogs / Manuals:
A4LD Service Manual
Mitsubishi 5-Speed (FM145 & FM146)
Mitsubishi 5-Speed Service Manual
1983-1987 Toyo Kogyo Transmission
1988-1998 Toyo Kogyo Mazda Transmission
Light Duty Transmission Transfer Case Part Numbers
BW1354 Manual Transfer Case
Automatic Transmission:
Automatic Transmission Troubleshooting
Ford Ranger Automatic Transmissions
Ford Ranger Fluids & Capacities
A4LD Automatic Transmission
C5 Transmission Diagnosis
Ford 4R44E / 4R55E / 5R55E Valve Body Gasket
Replacing A Ford 4R55E with a 5R55E
7-Common Problems With The Ford 4R55E Transmission
Automatic Transmission Fluid Change
Put A GM 700R4 Behind Your Ford 4.0L V6
Installing a Torque Converter lock up switch
Adjust / Repair Instrument Cluster Gear Indicator
A4LD Pressure Switch For Lock Up Torque Converter
AllanD’s Transmission & Transfer Case Guide
Manual Transmission:
Ford Ranger Manual Transmissions
Manual Transmission Troubleshooting
Ford M5OD Shop Manual
M5ODR1-HD Transfer Case Shift Lever Bracket
Clutch Pedal to Idler Shaft Bushing Replacement
Bleed A Hydraulic Clutch
Mazda Transmission Disassembly
Ford 2.9 Converted To 4.0 Clutch
Ford T5 Identification
T4/T5 Manual for Your Ford Ranger 2.9 V-6
Pilot Bearing Replacement
Mazda M5OD-R4 (M5R4) Manual Transmission
Shifter:
Shift Rail Plug Maintenance
Shifter Bushing Replacement
Build Your Own Shifter
Transmission Swaps:
Transmission Swap Options
A4LD to F146 (Mitsubishi) 5-Speed Swap
How to replace a M5OD-R1 with a M5OD-R1HD
FM146 to M5OD and Complete Clutch Upgrade
Installing A C5 Automatic Transmission on A 4.0 OHV
Transfer Cases / Trail Control:
Transfer Case Troubleshooting
Troubleshooting Your 2001-2011 Transfer Case
The Ford Ranger 4-Wheel Drive System
1983-2011 Ford Ranger Transfer Cases
Transfer Case Identification & Ratios
Borg Warner Transfer Case Identification
Borg Warner Transfer Case, Electric To Manual Shift Conversion
T-Case Exploded Views & Part Numbers
BW 1354 Transfer Case Exploded View & ID
Transfer Case Fluid Change
Ford NP205 Twin Stick Mod
DIY Twin Stick Levers
Transfer Case Shift Modules:
1995-2000 4WD Control Module
Troubleshooting Your 1995-2000 4WD Module
Checking 4WD Shift Module Circuits (1994-Older)
Transfer Case Shift Module Diagnosis (1994-Older)
Transfer Case Shift Motor:
Servicing A Transfer Case Shift Motor
Rebuilding A Transfer Case Shift Motor
Transfer Case Doubler:
Transfer Case Doubler Overview & FAQs
Dual Transfer Case Conversion
Building a BW1350-1354 Transfer Case Doubler
D&D Machine Transfer Case Doubler Install
Behemoth Drivetrain Strongbox
Driveshafts:
Building A Front Driveshaft For A 1998+ Ford Ranger
Fixing A Driveshaft ‘Clunk’
Carrier Bearing Relocation
Carrier Bearing Replacement
Checking Pinion Angles
1-Piece Driveshaft And Why You Want One
1-Piece Rear Driveshaft Swap (’90-’97 4WD Supercab)
All About Universal Joints
Double Cardan U-Joint Replacement
Pinion & U-Joint Angles
Explorer Front Driveshaft On Rear Of Bronco II
About The Author
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
