Can’t figure out my fuel guage
OldMan89
8
Tennessee
Ford ranger
My truck has a brand new in tank sending unit but my fuel guage doesn’t really work…some times I’ll start it up and BOOM it jumps right up but after about 3 minutes it has slowly made its way back down to empty. Not times it just downst move. I’ve checked connections and fuses but I am coming up stumped. Any input on what to look for would be greatly appreciated!
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
Have you checked the wire harness at the plug for the cluster, or check for damage/corrosion in the cluster it's self.
8,370
There is an anti-slosh module on the back of the instrument cluster, and you can test the sender OHMs when cluster is out
1989 sender should have these OHMs
16 ohms empty
160 ohms full
Sender wire at cluster will be the only yellow wire with white stripe on a connector
Hook up OHM meter to yellow wire and Cab ground
Should read between 16 and 160 ohms
Rock the truck, so gas sloshes around in the tank and ohms should change as float goes up and down
If you see that then sender and wire to dash are OK
Anti-slosh module is there to prevent just what you saw, OHMs going up and down every time you go around a corner, lol
It between the Yellow wire and the gauge, it averages the ohms over time, so no abrupt changes in the needle
Your symptom of the needle changing after a few minutes does read like a failing module
Google: 1989 Ford Ranger anti-slosh module
There will be videos and how-tos to repair, replace or bypass this unit
Get some dash bulbs, good to replace all 6 while dash is out, they are not expensive
OldMan89
8
Tennessee
Ford ranger
16 ohms empty
160 ohms full
Thank you so much! I appreciate you!
