freestyletrev
- Jun 30, 2015
- 0
- Ford
Hello,
I've posted about this before, but in a less specific way.
I have a 98 xlt, 4x4 5spd. I can shift into 4 high fine. When switched to 4 low, no relay clicks, no flashing lights. I've taken the motor off and it will turn either way with 12v and the tc can be turned in 4 low. I imagine this is a sensor issue. (speed, brake, clutch switch)
My brake lights work, and I can start the truck only with the clutch pushed in fully, so I imagine those sensors are fine. The speed sensor is probably/ hopefully the culprit.
Can anyone tell me what wires going into the GEM are for the speed, brake, and clutch sensors so I can just run ground/12v to them when I want to shift to 4 low?
