98 4x4 module/GEM wiring
freestyletrev
Hello,
I've posted about this before, but in a less specific way.
I have a 98 xlt, 4x4 5spd. I can shift into 4 high fine. When switched to 4 low, no relay clicks, no flashing lights. I've taken the motor off and it will turn either way with 12v and the tc can be turned in 4 low. I imagine this is a sensor issue. (speed, brake, clutch switch)
My brake lights work, and I can start the truck only with the clutch pushed in fully, so I imagine those sensors are fine. The speed sensor is probably/ hopefully the culprit.
Can anyone tell me what wires going into the GEM are for the speed, brake, and clutch sensors so I can just run ground/12v to them when I want to shift to 4 low?
8,372
Here ya go.
Clutch switch isn't just one switch, there are 3 switches in it, so in theory one of the switches could be broken and engine would still start, but longshot
freestyletrev
Thank you so much for the diagrams!
Would you happen to have diagrams for the 4x4 module also?
I don't see where the GEM has a clutch sensor input; just brake and speed. I know the clutch switch that I know of is located on the clutch pedal assembly. Where are the other parts of it? Included inside that assembly?
freestyletrev
Some of the diagrams wiring don't match up. I will have to wait until I can look at my wiring on my truck this weekend. This might be a life saver for me though! Thank you so very much!
