95 Explorer 4wd Donor for 93 Ranger 2wd
HighMileage93
8
Bridgeport, IL 62417
2.3l I4
I am looking at getting a rusted out 95 Explorer 4WD as a donor for a 8.8 rear swap to lower my 93 Ranger. Want to hear from all you experienced guys about what else I could salvage from this thing to use on my truck. Thanks.
Not much. Wheels and some body panels will swap, not much from the interior. Overhead console can be used if it has it.
scotts90ranger
4,370
Dayton Oregon
2.3 Turbo
Seats should be swappable but yeah, could be limited...
alaskan155
6
washington
FORD
7.3l/4.0l
as said not much
seats
could do a explorer clip swap(weld the explorer front fender pieces to the ranger fenders and swap the hood and headlights and stuff
drivetrain parts but sensors are a PITA
ford was nice and changed the plugs on the majority of the sensors even though they have the same number of pins....(found this out with comparing my 94 4.0 ohv explorer to my 2000 4.0 ohv ranger)
center console and Roof Compass/temp guage.
dome light
fuel pump and sending unit would be worth taking.
master cylinder has different port sizes so it wont swap, but if you swap in a 95-97(matches the 93-94 ports and has cruise switch port in it) ranger master and use the switches off the explorer steering wheel you could run the better electronic cruise with some wiring and get rid of the weak vacumn cruise.
a/c stuff, the a/c condensor will fit in the older a/c box
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
They changed the connectors when they changed the Electronic Engine Control in the switch from EEC4 to EEC5 in 1995!
HighMileage93
8
2.3l I4
Thanks again, guys. Think I am going to let this one go. I only really wanted the rear diff and the disc brakes but I think I'll just use mine and convert to Mustang rear brakes later.
HighMileage93
8
2.3l I4
Well, the owners of the 95 Explorer Eddie B 4.0 4x4 hit me with a surprise Saturday. They decided to GIVE it to me! Now I am back o what to do with it all. LOL
Take what you can use!, part the rest out.
