- Jun 12, 2023
- 0
- Tennessee
- Ford ranger
I’ve been having an issue where my truck dies over night. Went got the battery charged then I went and got it tested the battery alternator ect were all good. car battery drainage issue didn’t stop, and I’ve made some progress. I went around my truck, checking for anything, that could be causing the problem. And I found several fuses that were draining my battery. I took them out to not drain my battery. It turned out to be the Ac Clutch Solenoid, PCM Memory, Cigar Lighter, Data Link Connector (DLC), Battery Saver Relay, Auxiliary Relay Box, Restraint Central Module (RCM), Generic Electroic Module (GEM), Instrument Cluster and my radio fuse. I’m not sure how to fix them and put the so they don’t drain my battery when I put the fuse back.
any advice would help.
