Ford Bronco II GT Muscle
posted in: 1984-1988 Ford Bronco II | 0
What If Ford Built a 1986 Bronco II GT?
Long before the SUV became a home for performance, what if Ford had taken a compact Bronco II and turned it into a true factory hot-rod? Imagine a 1986 Ford Bronco II GT — a road-ready performance SUV built not for off-road crawling but for throttle-happy street driving.
This photo isn’t AI. This is an actual Ford Bronco II that someone lowered and then added a set of Mustang wheels and a Mustang hood scoop to. We don’t know any details about the vehicle, but it’s fun to image what it could have been.
Instead of the usual 2.9L V6 offered back then, this imagined Bronco II could have been powered by the Mustang GT’s fuel-injected 5.0-liter V8 and T-5 five-speed manual — the same combo that made the 1986 Mustang GT a surprising performer in its day.
Imagine if Ford had built a V8 powered Ford Bronco II GT.
Ford Bronco II GT Muscle SUV
Heart & Soul: Mustang GT Power in a Bronco II Chassis
In this alternate universe, Ford engineers drop the 5.0-liter V8 into the Bronco II’s engine bay, feeding it through a robust five-speed Borg-Warner T-5 manual. To suit the performance theme, this concept Bronco II also gets:
  • A Ford 8.8-inch rear axle with 4.10 gears and a Traction-Lok limited-slip differential for improved tire bite under acceleration.
  • 17-inch Mustang GT wheels to fill the wheel wells and improve stance and grip.
  • A 1979–1982 Mustang style hood scoop to hint at its powerplant heritage and add aggressive flair.
  • Upgraded four-wheel disc brakes and a tuned suspension setup to match the added performance potential.
Ford Bronco II GT
1986 Mustang GT Powerplant
The 1986 Mustang GT’s 5.0-liter V8 produced roughly 200 hp and 285 lb-ft of torque, sent through the five-speed manual gearbox and backed by the stronger 8.8-inch rear end. Transplanting this engine into a Bronco II would have turned Ford’s compact SUV into a muscle-car-powered performer — capable of impressive straight-line acceleration for its size.
1987 Mustang GT Spec Boost
For 1987, Ford refined the 5.0-liter V8 to produce about 225 hp and 300 lb-ft of torque. If Ford had carried this upgrade forward into the Bronco II GT, the imagined SUV would have gained a meaningful boost in performance, with larger Mustang GT front brakes and improved suspension geometry to match.
Bronco II GT rear
Sadly, a Bronco II GT Never Existed — But the Market Showed Up Anyway
As cool as this imagined Bronco II GT sounds, it never actually existed. Ford never offered a compact, V8-powered performance SUV in the mid-1980s — not from the factory, and not even as a serious prototype.
However, history did prove there was a real appetite for performance SUVs. In 1992–1993, GMC introduced the Typhoon, a compact SUV based on the Jimmy platform that shocked enthusiasts with its performance.
  • Turbocharged 4.3-liter V6 producing 280 hp and 360 lb-ft of torque.
  • 0-60 mph in roughly 5.3 seconds and a quarter-mile in the low 14-second range.
  • Sport-tuned suspension and upgraded brakes for better handling.
  • Four-speed automatic transmission and full-time all-wheel drive.
The Typhoon’s existence shows there was a market for a performance SUV. Had Ford introduced a Bronco II GT with Mustang power six or seven years earlier, it might have rewritten the early history of American performance SUVs.
GMC Typhoon
About The Author
