X-BULL XRS 13500 Electric Winch
X-Bull XRS 13500 Electric Winch
I remember when you were lucky to find a winch for under $500. I was excited to find a Warn XD9000i back in 2000 for $500. Over the years I’ve owned Warn, Mile Marker, and Smittybilt winches. I recently discovered this winch, and I’m really impressed with its features.
This X-Bull 13,500 Winch with its synthetic rope, tucked away winch hook and wireless remote control is an amazing value for under $500, and I will be adding an X-Bull winch to my next project.
Features
IP67 Waterproof: It has a new generation of wireless remote control, with an IP67 waterproof rating, that can operate accurately from a distance regardless of geography or weather. The wired and wireless control (up to 35m) are both included in this multipurpose controller. Provides 100 feet remote range control during the wireless. When the green light is on, it is the wireless remote-control state. When the red light is on, it is the wired remote-control state.
6.6 HP Series Wound Motor: New design 13500 XRS series winch with 6.6 horsepower 12V DC motor which enhanced the power output. Series-wound motor provides maximum torque and class-leading pulling power, with lower amp draw.
3-Stage Planetary Gear System: With the latest and effective 3-stage planetary gear system, free spooling clutch, and ability to provide strong traction under load and higher linear speed, it will become an indispensable partner in your journey.
Fast Line Speed: This winch has an impressive 3.8 fpm (1.05 mpm) line speed which is actually faster than the 3 ft/min (0.91m/min) on the Warn Zeon XD 12-S.
Automatic Double-Disk Brake: Brake placement in gear housing helps keep drum cool during pulls, avoiding excessive heat and synthetic rope damage. Each brake system holds full rated load.
Durable: The black frosted paint with new material will not rust and it improves the model’s thermal insulation and model’s durability. The all-steel shell can protect the winch well.
Synthetic Rope: The synthetic rope is lightweight but strong, and it is suited for all types of harsh environments due to its high resistance to bending, abrasion, and weather.
High-Quality Aerospace Aluminum Fairlead: This fairlead, made of high-grade aircraft aluminum, provides optimal performance for all your recovery requirements. Effectively control the traction angle, make the force more uniform, and protect the winch rope to achieve rapid escape. It boasts a working load limit of 20,000 pounds. The new design makes it easier for the gearbox’s heat to be dissipated, ensuring that the winch can operate for a longer period.
Clevis Winch Hook: The clevis winch hook fits neatly into the fairlead and is held in place by strong magnets so there’s no hook dangling off the front of your winch.
X-Bull Fairlead
Specifications
Rated Line Pull
13500 lbs (6123 kg)
Motor 6.6 HP Series Wound
Gear Train 3-Stage Planetary
Gear Reduction Ratio 216:1
Brake Automatic In-The Drum
Control 2 in 1 Multi-Functional Remote Control
Battery 12V DC, Minimum 650 CCA
Battery Cables 3.5 Gauge, 6′ (1.8 m)
Fairlead High-Grade Aircraft Aluminum Fairlead
Cable Type Synthetic Rope
Cable Size (D x L) 3/8″ X 92′ (9.5 mm X 28 m)
Overall Dimensions (L x W x H) 23.6″ X 13.4″ X 10.2″ (600 mm X 340 mm X 260 mm)
Drum Size (D x L) 2.5″ X 9″ (64 mm X 228 mm)
Bolt Pattern 10″ X 4.5″ (254 mm X 114.3 mm)
Weight 59.50 lbs (27.00 kg)
Waterproof Rating IP67
Line Speed (Max Line Pull) 3.8 fpm (1.05 mpm)
Amp Draw (Max Line Pull) 425 (@ 12V)
Application Truck/Jeep/SUV
In The Box
  • 1 X 13500 LBS Winch
  • 1 X Multi-Functional Remote Control
  • 1 X Aluminum Fairlead
  • 1 X Control Box
  • 1 X Battery Wire Harness
  • 1 X Hook
  • 1 X Set of Bolts
  • 1 X User Manual
Video
Photo Gallery
About The Author
