Auxbeam 7-Inch Round LED Lights
Auxbeam Ray-L LED Off-Road lights
Introduction
Buying bright quality off-road lights shouldn’t cost hundreds of dollars. Auxbeam has a reputation for providing quality off-road lights at an affordable price.
These Auxbeam RAY-L Series 7-Inch Off-Road Lights come with a wiring harness and built in white and amber daytime running lights (DRL). The amber could be wired to act as a turn signal or a fog light.
Ray-L Series 7-Inch LED Off-Road Lights
Features
Dual DRL (Daytime Running Light): Different ambient lighting you choose, included white daytime running light and amber daytime running light.
Ultra Brightness: Based on the powerful power, off road driving lights can provide up to 25800LM of luminous. The lighting distance can reach up to 646M, which can illuminate the entire road at night to ensure your driving safety.
IP68 Waterproof Design: Auxbeam LED work light features IP68 waterproof rating, high-quality housing and sturdy brackets. This ensures that rain, fog, moisture or dust cannot seep and cause damage. Rugged die-casting aluminum body designed for optimal heat removal, handles rough off-road environments and resists corrosion.
Quick Installation: Easy to connect and install with the included DT connector harness wiring kit, eliminating the hassle of redundant wiring. Durable wiring can meet your needs to install the lights anywhere in the vehicle.
Wide Application: The led driving light fits for almost all Off Road Vehicles, ATVs, UTVs, SUVs, Construction Vehicles, Farm Vehicles, Trucks, Motorcycles, Buses, Pick-ups, marine, Boat, etc..
5 Types of Lighting Effects:
  1. Main Light
  2. Amber DRL
  3. White DRL
  4. Main Light +Amber DRL
  5. Main Light + White DRL
Auxbeam off-road light specs
Specifications
  • Size: 7-Inch
  • Quantity: 2PCS
  • Power/Set: 240W (Main Light 119W+White DRL 20W+Amber DRL 20W)*2
  • Light Pattern: Spot Beam
  • Total Lumens: 25800LM 19800LM+White DRL 3000LM+Amber DRL 3000LM
  • Lighting Distance: 1lux@646M
  • Light Beads: 18PCS(SST-20F) + 48 PCS (3030 Dual Color)
  • Color Temperature: 6500K/3000K
  • Light Color: White & Amber
  • Housing Material: Aluminum alloy
  • Lens Material: PC
  • Lifetime: 50000+ hours
  • Waterproof Rate: IP68
  • Working Voltage: 10V-30V
  • Warranty: 2-years
Auxbeam off-road lights wiring
Packing Included
  • 2 X LED Driving Lights (With 4 Pin DT Male Plug?
  • 2 X 4 Pin DT Female Plug to 2 Pin DT Male Plug Adapter with White & Amber Light Cords
  • 1 X Wiring Harness With 2 Pin DT Female Plug?
  • 1 X Screw Accessories
  • 1 X Manual
Warranty Terms and Conditions
Auxbeam products are guaranteed against manufacturing defects for 2-years from the original date of receipt. Our sole obligation in the event of such defects during this period is to repair or replace the defective part or product with a comparable part or product at Auxbeam’s sole discretion.
If the item stopped production or out of stock, Auxbeam will offer a refund, or customer can pay balance to get another one. Refund for any overpayment or a supplemental payment for any deficiency. (Clearance items don’t enjoy warranty service).
Check Out
Video
More Photos
About The Author
