- Nov 26, 2009
Went electrical, mounted it within 16" of the tank
been there, done that. inside of 3 months that pump will fail.......
and mine was 6" from the tank, the shortest I could make it with a filter in front of it.
worse yet, it started drawing so much power that the fuel pump driver in the ECM burned out.
4 fuel pumps, and an ECM in 1 year is where I am coming from here
She runs great and starts right up, but Bogs down when she gets warmed up.
you know, this is exactly what my fuel pump did, remember rico that horrible sunday afternoon we drove to your shop, and kept having to pull over every 5-10 minutes and let it cool down before we could go again? pretty much the pump was working so hard (they aren't designed to "suck") it would heat up, and lose its ability to keep up. after that day, it was the final straw, I reconfigured the pump to be gravity fed, and have had the exact same pump for 3 years now.
my suggestion for testing if this is what is happening to you, is when the truck is ice-cold go out and hot-wire the pump so it runs continuously for 20 minutes or so without the engine running. then start it and see if it acts all boggy when the engine is cold.
next I would disconnect the o2 sensor and see if that solves anything. you are using the GM ECT sensor right?
