2006 FX4 Daily / Offroad Build
There are definitely a few options when it comes to the wiring and I would say it honestly depends on how far or what features you want to have added to the Ranger. Unfortunately for myself I want to have all the options which means more work for myself. 🤣 By this I mean the Explorer came with a range of options when it came to their seats. The driver and passenger in most cases were power but it there was an option for manual and power lumber, heated seats and memory (driver only). I was lucky enough to have sets from Limited Explorers that had all the options for both driver and passenger.
To start the power option on the driver Mustang seat isn't worth trying to splice and make work. So I removed that wiring harness completely and threw it away. Included in that was part of the power lumber the driver Mustang seat. You don't need that wiring as I mentioned the Explorer had it as well so it already wired and they are same connectors. so is plug and play on the wiring side. The passenger seat I am still working on adding the power lumber because I have take the seat fully apart but since it was an option for the driver seat I know I can get it to work.
The next step was to get the metal center support installed. Because it fits exactly the same as the Explorer I used JB Weld and got it in place and let it cure. I would honestly want it welded but I don't have that as an option. JB Weld will though work fine cause it only needs to hold the wires and metal center support fits snug. You could honestly do this part and zip tie and the wiring from the Explorer to the Mustang seats but I couldn't let myself do that when a factory look was a possibility.
After I got the wiring in place I had to make a hole in the leather for the power adjust buttons to go through. On the last picture in the previous post you can see it to the left. I thought I was going to have to drill a hole but some how again the Mustang frame was a perfect match and there was a hole already there to pass the buttons through. After this connect all the connectors to the right one (the heated seats won't be connected because they need to have the seats apart) and wire the seats to 12V power source or per the standard Explorer seat swap directions and you will have full power Mustang seats in a Ranger!
Still need to show how the seat belts worked out and then also show the intend to get the trim from the Explorer seat to Mustang seats, but for now here are pictures of them installed
Passenger side still needs to have the hole cut in the leather for the all the switches and the seat belt installed but on the driver you can see the seat belt installed. As well as the working power lumber
Realized I didn't really take pictures of the seatbelt install but I will on the passenger and post them later on but I will still go over the install
On the Explorer and Mustang the seat belt receiver or part the buckle goes into (not sure the actual name of it) is on the tracks. For the Ranger the seat belt receiver is on the seat and I wanted to try to keep the Ranger one because it has the tensioner in case of an accident but also it will plug in like normal and remove the airbag light on the dash.
The first step is to modify the Explorer track and cut off the two attachment points and slider for its seat belt receiver, next was getting the receiver attached to the Mustang seat.
My initial thought was to use the bolt that connects the back of the seat to bottom but the stud was to big diameter wise and the tensioner was showing and not in a good placement.
So I took apart the bottom of the seats, partially removed the leather and foam to access the metal frame of the seat to find a place for me to figure out have to mount the receiver. To my surprise though a hole was already in basically the perfect spot. The only thing needed to be modified was the Ranger receiver has a small notch extension in its bracket to help with alignment. So I laid out how I wanted receiver to be and marked out the extension. The extension is curved so to get that curve I drilled out three holes (both ends and middle) then finished the cut with a Dremel. The last step was if I wanted the receiver under the leather or over it. I ended up deciding to go under for a cleaner look. This required a small cut in the leather to let the receiver pass through. After this was done just a bolt and nut was need and the receiver was attached and moving with the seat just like factory on the Ranger!
Should have the passenger side worked on this weekend and can get more in progress pictures of that seat!
As I mentioned the other big modification was combining a set of 06-10 Explorer mirrors that had puddle light and heated mirror from the factory. When looking on Muth for the turn signal and heated mirror the Ranger I notice the 06-10 Explorer mirrors were exactly the same as the Ranger. So during a trip to the junkyard I compared the two and they were the same! The difference unfortunately was base but I figured there had to be a way to get them to work. I found a nice set that also which also had the painted black cap.
First step was to get the Explorer and Ranger mirrors apart to see how the base differed and how the heated mirror and puddle light were installed from the factory. They were both the same take the mirror off but unclipping it from the motor. Only difference was the Explorer had the wires attached to the mirror for heat.
After the mirror is off you can take the motor off which is 4 screws. The wiring are just push fittings so you just pull them off. Last was taking the cap off which is just unclipping it from the plastic of the housing.
After taking about the mirror it was easy to see how I could transfer the heated mirror over to the Ranger. Next was the puddle light.
As I mentioned the base is different from the Explorer to the Ranger but the difference is where it mounts to the door not the underside that has the puddle light. My thought process was to trace and cut the hole in the Ranger mirror. So I taped out base and followed the curved line to make sure I could line it up in the same position on the Ranger. The first picture is the Explorer and second is the Ranger.
Here is the cut out done on the Ranger.
I was actually pretty happy with how the cut came out and thought the light was going to snap in with no issues. But after cutting the Ranger mirror I realized the internal plastic was a lot different.
I then started cutting out the internal plastic to allow the light to snap in. I did eventually get the light to snap in but I realized it would never sit correctly or how it was from the Explorer. Since the opening on the Explorer was molded to have the light fit I decided to cut a larger hole on the Ranger and then cut that same size out of the Explorer and JB Weld that to the Ranger.
Here is the larger hole cut on the Ranger and the internal plastic cut out also.
I also was test fitting the wiring because I had to reroute it allow the light to fit.
