Lift pump to high pressure in tank setup
Featured Build Threads
I bought the kit with rolls of both from Amazon and ended up using the factory connectors on their "3/8" line... Definitely not ideal.
I ended up having to to reuse the 3/8 fro the factory lines as well. All in all she is running again and no leaks. Haven't road tested yet to see if it holds and my top end fueling issue is gone.
Although towards the end it became a whenever I put a load on it.
So we will see how it turns out when I get the bed back on.
She seems to be running good!
Brought it up to operating temp and went for a short spirited drive. Power stayed consistent and don't cut out. Here's to hoping that stays the case.
For fun I hooked the old pump up to 12v and it started fine, but after about 2 seconds it started fluctuating in speed and at the 6 second mark was barley running. So safe to say it was an issue.
Featured Ranger Based Vehicle
