Swap Dana 28 E4wd to 2001 Ranger Edge 4X4
Blown
We got a decent snow so I got out and played a bit. :yahoo::headbang::yahoo:
It is just like 4 wheel drive!
I can punch it off the line and spin all four instead of just the rears. The big improvement with this case is the AWD. The trade-off is the loss of Low. It is nice to flip a switch to get out of a sticky or slippery situation.
Icuff4cash
Las vegas
V6
Aerostar owner needs help
Hello blown that was a great write up . I have a question I would like a stronger front diff and axle unit in my areostar. That's the weak link. Your write up of useing the Dana 28 changed my mind. I was going to put a 1354 because I go camping and thought a tc28 was junk. After reading your write up I'm going to keep it. Any ideas or were I could get information on a sas. It seams theaxles are the problem. I'm not going mud bogging just beach off road camping. Would a ranger diff fit my van and just axles would have to be made? When I was young I ran a Ford 9" in my firebird. And smother brothers axles were made because the rear was shorten to fit the firebird. Is it possible to run with just custom axles. But a new diff would get me a possi if needed to get out of stuck sand or snow.
Robert
94 aerostar xlt lwb
4.0 auto and running 235-75-15 tires on Jeep Grand Cherokee rims. No cutting and they fit.
wildbill23c
577
Southwestern Idaho
215/70-R14
Wow great write up Blown. Very interesting. Guessing though that t-case setup is limited to that particular transmission and won't work on other transmissions, such as the A4LD?
Blown
Thanks! Sounds like you got a cool project! I do not know what would swap into an Aerostar. Is there an Aerostar Forum?
Robert
94 aerostar xlt lwb
Blown
The Ranger shares the 5R55E with the Aerostar. Both utilize a 5 bolt pattern to bolt to the transfer case. I think the A4LD is different.
donaldcon
19
Lancaster, Oh
The bw1354 will bolt on to 5r55e.
I have put one in an Aerostar and I have used a 5r55e from a 2001 Ranger in my Bronco 2 and bolted a 1354 to it aswell
Sent from my SAMSUNG-SM-G891A using Tapatalk
Clemenchino
Blown! How do you do the switch?
Hi blown I want to make the same switch to the Dana 28 how do you do the switch?? Do you have pictures??
It's possible to do a 3 way switch:100% rear, 75% rear 25% front and 50% rear 50% front??
Thank you '
Blown
Thank you '
The Dana 28 will bolt-up to the 5r55E, No pics just what is here, not possible to do a three way switch. I got Aerostar driveshafts and had them sized to fit. I wired a switch to lock it in 4X4 whe3n need at low speed to get unstuck or moving on a very slippery surface.
I traded back too the stock transfer case just last weekend. I wanted 4X4 low back. I was not satisfied with a rear driveshaft vibration, though it could be fixed. I have a camper shell now and plan on getting out into the Rockies to play and camp. I will use 4low.
The AWD was awesome at cornering, the front wheels pull yo around a corner rather than being pushed. It was excellent on snow/ice, no forced
slippage like 4X4.
I have the Dana 28 transfer case and driveshafts. Drive shaft to fit an extended cab.
Clemenchino
Thanks, good to know but what about the 50% rear 50% front switch. Could you make it work?? If you can how do you make the switch? Cause I want to control it. Not the machine.
slippage like 4X4.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
slippage like 4X4.
Shot in the dark here, but still have the TC28?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
there was a couple near my house in detroit.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
I'll give ya tree fiddy for it
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
$3.50? Cheep skate....
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Probably 100 bux....it's a shelf yard. Seen them in there when I was looking at mt82 transmissions.
