MAJOR braking problem
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Okay, so as you all know, Im building a long travel suspension on my ranger. It's about done, but I cant seem to get my brakes back.
All brand new lines run, new Explorer master cylinder, and new brake hoses. MC was bench bled and installed properly. All fittings are TIGHT. I've tripple checked that.
Problem: It feels like I have great pedal when the vehicle's shut off. There is a steady stream of fluid out of every bleeder valve (NO air bubbles). But, as soon as I turn the truck on, my pedal goes straight to the floor.
Does anybody have a CLUE as to what's going on here? Only thing left to replace is the booster...
:icon_confused:
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Exactly what happened when my brake booster went out on my Mustang. That was very scary.
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Did you have the calipers off?
-PlumCrazy
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
pillen140
45
winston-salem, NC
bleed them 15 more times. I doubt the booster went out all of the sudden. make sure to start with the wheel furthest away from the mc. it will come back I bet.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Is it possible you put the calipers on the wrong sides? (bleeders lower than hose inlet)
-PlumCrazy
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
That's EXACTLY what I did.... *face palm*
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Piss..... good call Plumcrazy.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Definitely!!!
+1 dude.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Nevermind, I just went and checked...They ARE on the correct sides....I didnt THINK I'd do that....but ya never know.
Any more suggestions?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Sounds like air in the master still then.
-PlumCrazy
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I spent half an hour bench bleeding that thing. I can garuntee you there's no air in the MC.
I'm going to keep bleeding everything and see what I end up with.
If nothing changes, I'll try a new booster.
This shit has me irritated beyond belief. :flipoff:
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Have you pulled the check valve to see if you have vacuum present at the booster? Could just be a check valve.
pillen140
45
winston-salem, NC
do you have abs?
Do I need to come out, look at it for 10 minutes, scratch my head, and give up?
Also, have you pulled the booster hose and tried it with the engine running?
