mightysonofa
- May 1, 2011
- Reaction score
- 2
- Location
- mars
- Make / Model
- ford
- Engine Size
- 2.8
- Manual
I have a 84 b2 2.8L with 119,000 0n it . out of the blue it started to make a strange rattle noise heard either at cold start and then after warm up at idle , it sounds like very loose lifters it does not hesitate or lack power nor does it have a miss ,I have always changed the oil and other than the rattle noise it runs and drives fine .If I go to start it and it doesn't start right away as the engine is still spinning a bit you can hear it the best . it almost sound like something in the bottom of the engine not a rod but a loud rattle. Like something rolling around in there I've checked the exhaust it is all brand new from the y pipe back even the cat is new .if it is making the noise as soon as I give it a bit of gas it goes away .I took it to a shop they said it has low oil pressure . If so do I need a new engine or should I pull the engine and replace the pump then adjust he valves and see what's up after that .I haven't had much experience with these old engines . one guy told me it sounds like the timing gear has broken off but I don't hear the noise under the hood just under the truck in the lower engine . Any Ideas?
