1989 Ford Bronco II Fuel Problem?
mazdaford02
I have a 1989 Ford Bronco II 4X4 XLT it has the 2.9l EFI with the redesign heads. It has 150,000 miles 4-speed OD manual trans, manual hubs, manual transfer case. I have noticed that it is reluctant to start, but its more complex than that. I turn the key, wait for the fuel pump to stop humming, and it will fire, run for 3-5 seconds and then die out. I go back after a couple of seconds and it fires right up with no problems. There are no other issues and starts fine when warmed up. I haven't been able to isolate the problem.
Recently I have performed a complete tune-up: Spark plugs, wires , distributor, cap, rotor, oil, oil filter, air filter, fuel filter, TPS, new valve cover gaskets.
I also put in a new fuel tank recently and new leaf springs as well as brakes.
I looked into it a little bit, the fuel sending unit is operating as it should but if ound that there is a secondary pump or pressure regulator? Agian it is EFI and has no other known problems.
Can anyone help?
3,614
Well, you only have the one fuel pump, but you do have a pressure regulator.
Try priming the pump more than once. If that helps the check valve in the pump is bad.
mazdaford02
I have had some luck with that, priming it 2-3 times and it will fire okay, forgot to mention that. So it is most likely the pump or is this pressure regulator another possible issue.
I was going to change the pump when i did the gas tank but was in a hurry and thought I could get away on the old one if I held the tank above half.
3,614
The only thing the pressure regulator does is control how much pressure is built up in the rail when the engine is running.
I would do a fuel pressure bleed-off test. Hook a gauge to it, run it for a few minutes, and then let it sit overnight, see what is left first thing in the morning. If it is 0, get a new pump.
mazdaford02
Alright, thanks for the quick response. I will post update when problem is resolved.
