Cb radio
Ok thank you, and to tune it with my cb because I believe it has a swr built in I just need to adjust the diald
adjust the antenna length. whether its using the little deal under the antenna cap that is mentioned above, or adding a spacer to the antenna, or trimming some off of the wire. depends on your antenna.
from googly:
Tuning a CB antenna involves adjusting its physical length to minimize the Standing Wave Ratio (SWR) for efficient, safe operation. Using an SWR meter, you measure performance on Channels 1 and 40, then adjust the antenna’s tip or whip in small increments until SWR is below 1.5-2.0 across the band.
Steps to Tune a CB Antenna
  1. Prepare the Environment: Park in an open area, at least 40 meters away from buildings, trees, or metal objects, as these interfere with readings.
  2. Connect the SWR Meter:Connect a coax jumper cable from the radio's "ANT" jack to the "RADIO" or "IN" port on the SWR meter. Connect the main antenna coax to the "ANT" or "OUT" port on the meter.
    • Check SWR on Channel 1:
      • Set the radio to Channel 1.
      • Set the meter switch to "FWD" (Forward).
      • Key the microphone (press-to-talk) and adjust the knob so the needle hits the "SET" mark.
      • Switch the meter to "REF" (Reflect) or "SWR" and record the reading.
    • Check SWR on Channel 40: Repeat the above process for Channel 40 and record the reading.
    • Interpret Results & Adjust Length:
      • If SWR is higher on Channel 40: The antenna is too long. Shorten it by turning the tuning tip/screw down, or cutting the whip in 1/8-inch increments.
      • If SWR is higher on Channel 1: The antenna is too short. Lengthen it by turning the tip/screw up.
    • Repeat: Repeat steps 3–5 until the SWR is roughly equal on both channels and as low as possible (ideally under 1.5).
Important Tips
  • Safety First: Do not hold the microphone for more than 5 seconds while checking, as high SWR can damage the radio.
  • Replace Tip: Always replace the antenna's weather cap before taking final readings, as it affects tuning.
  • Initial Setup: Ensure the antenna mount has a good ground connection to the vehicle chassis.
  • Small Changes: Make very small adjustments to the antenna length, as even 1/4 inch can significantly change the SWR.
  • How to tune a CB Antenna
    Adjusting the length of a CB antenna is crucial for proper tuning based on SWR readings. If the SWR reading on channel 40 is highe...
    YouTube·Right Channel Radios
    7m
  • How-To Tune a CB Antennae
    Tuning a CB antenna is necessary for it to perform correctly and prevent damage to the radio. An untuned antenna can damage the ra...
    YouTube·BleepinJeep
    7m
  • How to Tune Your CB Antenna
    Set the switch on the SWR meter to “FWD.” Turn the radio to channel 1. Key the microphone (depress the button and hold it). Turn t...
    Right Channel Radios·
    5:46
There is a bunch of info on CB's in the tech library:
from googly:
Important Tips
    7m
    YouTube·BleepinJeep
    7m
    5:46
Thank you, I’m thinking I’m gonna get a 4 foot antenna just to try this all out for now but I’ll watch these videos to learn, thank you
If your CB has an output power setting I'd suggest turning that right down to the minimum while you do you antenna tuning too. That'll be easiest on your output transistors.
This might help you guys know what cb I have
Cb radio
Do you have the user manual? I just found it online and the antenna running procedure is pretty easy and straightforward on that radio. Basically you key up the mic, calibrate the meter to full scale with the SWR/CAL switch set on CAL, then tune your antenna until you get the lowest reading with the switch set to SWR.
  • Cb radio
  • Cb radio
nice cb. i like cobras. as you play with it, there are little things you can do to make it more powerful too. thats for later on if you like it though.
adding stuff inline to make it more powerful can get you in trouble though. i forget what the amplifier is called some people use with a cb but that can make you get visits from different types of government people you might not want visiting you so don't fall for adding those types. a linear amplifier? something like that
I don’t really care for Rang I mean sure it’s cool I just want the cb and I want it to be halfway decent still I just want a cb I think there cool
No I got the cb for free
We’re do you guys run your wires thru the truck besides the back window? Or is that the only option besides drilling a hole
you can use the cabin vent or there should be some rubber grommets you can also pierce and push the cables through
i liked having a cb, back when i had one in a vehicle full time, because it gives you something to listen to while driving. listening to the truckers talk back and forth.
and if you find a nice clear hill top, you can also listen to people from farther away places talk about all kinds of stuff.
We’re is the cabin vent?
