Cb radio
Nobody's mentioned it yet, but power lines put off a ton of noise, especially the high tension megawatt transit lines that run through cleared areas between substations. I was an idiot and tried to adjust my SWR underneath one. šŸ˜…
Yea that might mess it up
Oh it was a bit of a head scratcher. The homeowner had a grasp of electrical and a Fluke meter but he couldn’t figure it out. I went through things and found a couple minor issues. Called my one contractor buddy and we both beat our heads against the wall for a bit until we realized that the problem wasn’t with the house electrical for sure, then we told the homeowner to call the power company and tell them it’s their problem because two electricians have checked the house wiring and the problem is exterior. Power company (reluctantly) sent a guy out who went up the pole and said it was a bad connection that the previous power company guy missed (the transformer had been replaced). We had a good 5+ volts on the ground wire.
Ok
They say the first of the 12 steps to beat addiction is to admit you have a problem. So here goes:
I have a problem. I’m a junkie. I admit it. I need help, maybe intervention….
Today I bought a 1980 - 1983 Realistic TRC - 465 40-channel AM/SSB CB radio. It’s compact, about 2/3 the size of my Cobra 29LTD Classic, maybe half the size of my Cobra 148GTL AM/SSB. No box or paperwork, but the thing looks like it came out of the showroom yesterday. It’s the twin (same guts) as a Uniden PC-122, I’m downloading the manual. I think this one has been peaked.
They apparently sold new for about $160 - $180 in 1981 to 83, and clean used ones are still selling right now from $100 to $140 bucks. I paid $30, stole it, I love craigslist/marketplace
I might put it in one of the Towncars, or I may simply trade it to my workshop when I bring in my 148s and 29s for peak, cleanup and adjustment. Right now it’ll be a base at my test stand in the shed of miracles.
I think you got ripped off... Its worth $5 at most. I'll send you $5 for it if you pay the shipping.....
PS, I'm in Canada.
PS, I'm in Canada.
Canadians…..
tsk, tsk……
For an SSB? The one and only SSB produced and sold by Tandy/Realistic? The Radio Shack holy grail????
The investment and sentimental value is worth at least $1000…..
If you’ve got half a radio, we could set a time, and I can key that thing up down here and I tell you about it using the skip…
I'm such a sucker for red seven-segment LEDs. Reminds me of the best tech decade ever, the 70s. :LOL: I'm 90% serious there.
Serious question for Rick W or one of you guys who knows these radios and the CB regs fairly well: IIRC, the FCC legal power limit for CB is what, 4 watts? Do these rigs put out the full 4 watts on SSB or are they limited either by design or by specific SSB regulations? 4 watts on AM is, well, not a whole lot... but 4 watts on SSB, I've made contacts all over the world on 10m with 5 watts when the conditions were right.
Since just about the beginning of time, 4 watts is the legal limit for broadcast output on a CB. Technology varies though, and the clarity of what you send and receive can be greatly improved with a Cobra or such. Antenna type and location is at least 50% of the equation.
When I was young (60-70s) you had to have a license for a CB, kind of like you have to have for a GMRS radio now. When the craze went crazy late 70s for about 10 years, they eliminated the need for the license.
While 4 watts is still the legal limit, a lot of radio shops (and just independent geeks) know how to tweak the radios to get some more out of them. But you have to be careful with that. The radios are designed with a little buffer, and don’t broadcast at their full potential. That’s a safety factor so you don’t burn them up. A lot of times when you get them ā€œpeaked,ā€œ the tech will push it to the limit, and after a period of time you can burn it up. It’s usually a lot cheaper to buy a better quality radio than to buy a cheap one and then pay somebody to modify it. And yes, modifying them is illegal.
Having said that, the technology and circuitry in some radios makes it much more easy to pump up the output. Understand that that’s just the output. So if you push out more signal, people will be able to hear you, but you may not be able to pick up their response.
SSB: A single side band is actually what it sounds like. When you broadcast on the regular AM CB 40 channels, you’re broadcasting a wave at 4 watts. With an SSB, when you were on the upper side or the lower side band, you are only using half the wave/band. The effect is ā€œplus 2X,ā€ so you’re actually broadcasting at 12 watts. That is only when you are in the upper band or lower band, and only somebody with the upper band or lower band on that channel will be able to communicate. The ā€œclarifyā€ knob is actually simply a tuning knob. When you connect to somebody, if the signal is a little bit off, you can play with the clarify knob and bring them in better sometimes, many times.
SKIP: the regular 40 channel signal compared to the SSB signal is like a bullet compared to a softball. The softball carries well for a short distance, and it’s big so it’s easy to catch. The SSB signal is the rifle shot. It is narrow and it can travel much farther. With that rifle shot signal, with the right atmosphere conditions, the signal can ā€œskipā€ off the bottom part of a heavy atmosphere (like clouds, but it doesn’t have to be cloudy), and that signal can go great distances. Having a good clarify is usually mandatory to pick up those distant signals. Usually that skip feature goes in both directions, so you can talk to people very far away sometimes.
I use my radios to stay awake, ask local directions while I’m driving, etc. I’m not using them to talk to people far away from my social life, not that I’m knocking. If you want to use them for a good communication and long distance communication. Do you want the best radio you could get, and a very good antenna set up.
Another note for the modern day: there are radio listening sensors all over the place these days, like radar traps, but nobody is manning them. If they pick up a heavy signal, then they can go to the police or traffic cameras, or who knows what, and find you, and justify the taxes we paid for the government to keep guys like you under control.
Hope it helps
