Don't know anything about it. It uses drop brackets and extended radius arms for the front, which is the right way to do it. The question is, how well are their brackets engineered. The biggest problem I'm aware of with Rough Country is that their brackets somehow allow something to poke a hole in the differential housing, I would guess during big articulation. If Tough Country does NOT do that, then this might be a good kit, or at least a good starting point that could be modified and strengthened later if necessary. The add-a-leaf for lifting the rear may be ok. I would prefer that instead of blocks any day. But new springs with more arch are the best way to go there. Longer shackles could be used also to adjust rear ride height.
I know the dilemma of wanting to achieve a goal that happens to be expensive. I would be an idiot if I didnt6recommend being patient and saving more money so you could get a kit from Skyjacker or James Duff. But I've been in your shoes many times. My best advice is "do as much research as possible before buying." And that's seems to be what you are doing. Try to study as many of the articles in our tech library as possible and weigh that with the answers you get here.
DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe … Continued
www.therangerstation.com
