Introduction:
Once in a great while I’ll see a post where someone has complained about the front wheel bearings coming loose on their 1983-1997 Ford Ranger 4×4. This generally happens after someone has reinstalled the spindle lock nuts and not properly tightened them.
Here’s how to properly tighten the spindle locknuts after you’ve installed a grease packed wheelbearing in the brake rotor:
From MAKG
For manual locking hubs, inner nut to 30 ft-lbs, rotate rotor, retorque 30 ft-lbs, repeat until no change. Back off 1/4 turn. Tighten to hand-tight (I think the spec is 16 INCH-lbs). Install washer without turning inner nut. Install outer nut to 150-250 ft-lbs.
From 4x4Junkie:
The way I do mine (not a whole lot different from what MAKG posted):
- Pack liberally with a good quality lithium-base wheelbearing grease (I use Castrol Wheelbearing Grease)
- Assemble it and tighten the nut to 35 ft-lbs while spinning the rotor back & forth.
- Back it off a half-turn, then retighten to 15 INCH-lbs (about what you’ll get by tightening it until snug by hand with the socket)
- Install locking washer (flipping it over if the hole doesn’t line up, don’t move the nut)
- Tighten the outer nut to 250ft-lbs, making sure the washer tab doesn’t slip out of the spindle groove.
Chilton Manual:
- install the inner locknut on the spindle and tighten it to 35 ft-lbs.
- Spin the brake disc (rotor) several turns in each direction to seat the bearings.
- Loosen the inner locknut 1/4-turn, then retighten it to 16 in-lbs.
- Install the lockwasher and align the locknut pin with one of the holes in the lockwasher. If necessary, turn the inner locknut slightly to align the hole and pin.
- Install the outer locknut and tighten to 150 ft-lbs.
- Lubricate the needle bearing spacer and needle bearing (if equipped) with the same grease used for the wheel bearings. Install them in the spindle.
- Install the axleshaft spacer
- Install the snap-ring on the spindle.
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
