Custom built Headlight Wiring harness for 1993 - 2009 Ford Ranger
Featured Build Threads
I support common sense
Forum Member
N/A
TN - USA
Vehicle
Drive
2WD
3.0L
2”
15”
I've been doing lots of research on upgraded wiring harnesses, that would allow for a higher amperage drawing bulb or even using both high and low filaments at the same time. The default wiring for the Ranger comes off the multi-function switch. According to the tech libraries it loses about 10% of the voltage, which is equivalent to 1.2v. The tech Libraries say this causes a 33% decrease in light output. So, a lot of guys will run wiring straight from the battery through a relay to the headlights. Putco makes a wiring harness and so do several other brands, but they are all 100 watts and use 16-gauge wire. Not to mention they don't appear to use standard relays. I don't want to risk overloading these harnesses, and reviews say the connectors are low-quality plastic not ceramic. I'm considering building my own harness with the highest quality connectors, 40-amp relays, 14-gauge wire, and 16-gauge signal wire. I'm now wondering if anyone else out there is interested in their own custom harness. I'd be more than willing to build several more, I could build it to whatever specifications you want. IS anyone else interested in a custom-built wiring harness, or has anyone found a good pre built harness?
If you're going to run both high and low simultaneously, it may be wise to upsize the ground wire from lamps to frame, also.
I bought a “heavy duty” headlight harness from Bronco Graveyard. Actually I bought three so far but only one has made it into a truck. I’ve been pretty happy with it so far and it uses a standard 4-pin relay that I’ve bought extras of. The cost was considerably cheaper than I could build it myself
Upcoming TRS Events
Featured Ranger Based Vehicle
