DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities, it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
2019-Present Ford Ranger Tech:
If you’re looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Tires & Wheels:
How To Choose An Off-Road Tire
Tire Size Calculator & Size Chart
Buying Used Tires
1983-2011 Ranger Wheel Guide
Mustang Wheels On Your Ford Ranger
1983-2011 Ford Ranger Tire Fitment Guide
Tire Load Ratings
Trailer Tire Wear
Brakes:
Trouble Shooting
Brake Upgrades
Hydro-Boost Brake Conversion
Mustang Rear Discs For Your Ranger
Sport Trac 12-Inch Rotors For Your Ranger
Relocating Brake Lines – Front
Brake Line Extensions
Ford F-350 Brake Master Cylinder Swap
Replacement Extended Rubber Brake Hoses
Disc Brakes For Your Ford 8.8
Dana 44 Disc Brake Conversion
Explorer Rear Disc Brake Conversion
EBC Brake Upgrade
Spindle Lock Nuts (4×4 Models)
Tightening Your Spindle Lock Nuts
BlackBII’s Dana 35 Spindle Nut Mod
Dana 35 Jeep Locknut Upgrade
Warn Dana 35 Locknut Conversion
Steering:
Trouble Shooting
GM Electric Power Steering Upgrade
Toyota Electric Power Steering Conversion
Vacuum Bleeding A Ford Power Steering Pump
AGR Power Steering Pump
Saginaw Power Steering Pump Swap
Hydro Steering – Box Tap
Installing Full Hydro Steering
Ford Steering Box Rebuild
Steering Tech – TTB Steering & Alignment
Ford Steering Box Mild Rebuild
Front End Wheel Alignment
Intermediate Steering Shaft
Steering Shaft Rag Joint Replacement
2WD Turning Radius Correction
Camber (alignment) Bushings
Make A Ball Joint Tool & Replacing Ball Joints
Ball Joint Install
Sway Bar Bushing Replacement
Exploded Views:
1998 Brake Hub Assembly
2000 Front Disc Brakes
Calculators:
Convert Metric Tire Sizes To Inches
Speed Change From Tire Size Change Calculator
Check Speedometer Change After Tire Size Change
Website |  + posts
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
