1984 Ford Bronco II With Snowplow
posted in: 1984-1988 Ford Bronco II | 0
1984 Ford Bronco II With Meyers Snow Plow
This 1984 Ford Bronco II was recently found on the Barn Finds website. The Bronco II comes with the original 2.8L V6 engine and an automatic transmission, and the seller states that it has a 4-inch lift kit with new leaf springs, coil springs, and shocks.
The Western Plow appears to have been repainted and treated to new hardware. It’s surprising to see a 1984 plow vehicle that isn’t completely rusted out.
Price: $24500
Mileage: 67000
Title Status: Clean
VIN: 1FMBU14S3EUB76213
See the seller’s description below:
Seller’s Description: 1984 Ford bronco two 4 x 4 V6 automatic transmission 3:73 gears and factory western snowplow
second owner completely restored. Metal was replaced in areas directly behind all 4 wheels. 4-inch lift including new coil springs, leaf springs, shocks, Ball joints tie rods U joints, brake pads shoes drums hardware calipers slave cylinders brake lines (rubber and Metal)
fuel lines fuel pump sending unit fuel tank, radiator all fluids and filters have been changed including front and rear differential. Two-tone paint to match rims and coil springs hand Pin Stripe. Factory interior is mint other than one small tear in driver seat and head liner in falling but not torn. Factory Plow has also been fully restored with all hardware being stainless steel including the chain.
1984 Ford Bronco II With Snowplow - Interior
More Photos
Click to enlarge.
About The Author
