Towing With A Ford Ranger
Important Ford Ranger Towing Information
Before towing with your Ford Ranger, it’s important to understand the weight ratings and limitations (towing capacity) listed in the owner’s manual. These ratings are designed to help prevent damage to the truck and improve towing safety.
Ford states that trailer towing places additional stress on the engine, transmission, axle, brakes, tires, and suspension. Depending on the trailer and model year, towing may require a factory tow package or additional equipment.
NOTICE: This is a general guide. Consult your Owner’s Manual for more towing information. See the links at the bottom of this page for other related articles.
Follow These Towing Guidelines
Ford recommends the following when towing a trailer:
  • Consult your local motor vehicle laws regarding trailer towing.
  • Follow the installation instructions included with towing accessories.
  • Stay within your vehicle’s weight limits.
  • Use extra caution while driving with a trailer.
  • Do not drive faster than 55 mph when towing a trailer.
  • Service your vehicle more frequently if it is used for towing.
  • For high altitude operation, reduce GCW by 2% per 1,000 ft. elevation.
  • Deactivate Overdrive when towing up or down steep hills or use Tow/Haul mode on 2019+ Rangers.
Understanding Ford Ranger Weight Ratings
Cargo Weight – includes all weight added to the Base Curb Weight, including cargo and optional equipment. When towing, trailer tongue load or king pin weight is also part of cargo weight.
Payload – is the combined weight of cargo and passengers that the vehicle is carrying. The maximum payload for your vehicle can be found on the Tire Label on the B-Pillar or the edge of the driver’s door of the 2005 and newer Ford Ranger. Look for “THE COMBINED WEIGHT OF OCCUPANTS AND CARGO SHOULD NEVER EXCEED XXX kg OR XXX lb.” for maximum payload. The payload listed on the Tire Label is the maximum payload for the vehicle as built by the assembly plant.
IMPORTANT: If any aftermarket or authorized-dealer installed equipment has been installed on the vehicle, the weight of the equipment must be subtracted from the payload listed on the Tire Label in order to determine the new payload.
For more information see: Ford Ranger Payload Capacities
GVWR (Gross Vehicle Weight Rating) – is the maximum allowable weight of the fully loaded vehicle (including all options, equipment, passengers and cargo). The GVWR is shown on the Safety Compliance Certification Label located on the B-Pillar or the edge of the driver’s door. The GVW must never exceed the GVWR.
GCW (Gross Combined Weight) – is the weight of the loaded vehicle (GVW) plus the weight of the fully loaded trailer.
GCWR (Gross Combined Weight Rating) – is the maximum allowable weight of the vehicle and the loaded trailer– including all cargo and passengers– that the vehicle can handle without risking damage. (Important: The towing vehicle’s braking system is rated for operation at GVWR, not at GCWR.) Separate functional brakes should be used for safe control of towed vehicles and for trailers where the GCW of the towing vehicle plus the trailer exceed the GVWR of the towing vehicle. The GCW must never exceed the GCWR.
Maximum Loaded Trailer Weight – is the highest possible weight of a fully loaded trailer the vehicle can tow. It assumes a vehicle with only mandatory options, no cargo (internal or external), a tongue load of 10–15%, and driver only (150 lb.). Consult your authorized dealer (or the RV and Trailer Towing Guide provided by your authorized dealer) for more detailed information.
Tongue Load Weight – refers to the amount of the weight that a trailer pushes down on a trailer hitch. Examples: For a 5,000 lb. conventional trailer, multiply 5,000 by 0.10 and 0.15 to obtain a proper tongue load range of 500 to 750 lbs.
The Safety Compliance Certification label is on the driver’s door jamb and lists the trucks Gross Vehicle Weight Rating (GVWR) and the front and rear Gross Axle Weight Ratings.Safety Compliance Certification label
Tire and Loading Sticker
Beginning in 2005, Ford added a “Tire and Loading Information” label to the driver’s door jamb that clearly lists a truck’s maximum combined weight of occupants and cargo. For 2004 and older Rangers, however, that number isn’t spelled out so conveniently. Owners are left to interpret GVWR and axle ratings on their own — or guess.
Hitches
Hitch Selection – For towing trailers up to 2,000 lbs., use a weight carrying hitch and ball which uniformly distributes the trailer tongue loads through the underbody structure. Use a frame-mounted weight distributing hitch for trailers over 2,000 lbs.
Step Bumper – The optional step bumper is equipped with an integral hitch and requires only a ball with a 3⁄4 in. (19 mm) shank diameter. The bumper has a
2,000 lb. trailer weight and 200 lb. tongue weight capability.
Safety Chains – Always connect the trailer’s safety chains to the vehicle. To connect the trailer’s safety chains, cross the chains under the trailer tongue and allow slack for turning corners. If you use a rental trailer, follow the instructions that the rental agency gives to you.
Trailer Brakes – Electric brakes and manual, automatic or surge-type brakes are safe if installed properly and adjusted to the manufacturer’s specifications. The trailer brakes must meet local and Federal regulations. The braking system of the tow vehicle is rated for operation at the GVWR not GCWR. In other words, your brakes are designed to stop a properly loaded Ford Ranger, not the trailer. The trailer should have its own brakes.
WARNING: Do not tow a trailer fitted with electric trailer brakes unless your vehicle is fitted with a compatible aftermarket electronic trailer brake controller. Failure to follow this instruction could result in the loss of control of your vehicle, personal injury or death.
Trailer Lamps – Trailer lamps are required on most towed vehicles. Make sure your trailer lamps conform to local and Federal regulations. See your dealer or
trailer rental agency for proper instructions and equipment for hooking up trailer lamps. Please don’t be the guy that thinks he can tow a trailer without brake lights or taillights because you’re not going very far.
Ford Ranger with Overloaded Trailer
Maximum Loaded Trailer Weights
These towing ratings were sourced from original Ford Ranger owner’s manuals, sales brochures and Ford Towing Guides. Ratings varied depending on engine, transmission, axle ratio, drivetrain, cab configuration, payload, optional equipment, and towing equipment.
Ford Ranger Owners Manuals
Ford Ranger Brochures
Ford Towing Guides
Special Notes
3.0L Powered Rangers – When towing on roads with steep grades or moderate but long sustained grades (5-miles or more), or when ambient temperatures exceed 100°F, vehicle speed should not exceed 45 mph in both cases.
Splash Models – Optional payload is not available on 4×2 Splash or Special Suspension, therefore maximum trailer weight is 2,000 lbs.
2024 Ford Ranger
Engine Axle Ratio GCWR (lbs.) Maximum Loaded Trailer Weight (lbs.)
SuperCrew 4×2 SuperCrew 4×4 AWD
2.3L EcoBoost I-4 3.73 12,370 7,500 — —
2.3L EcoBoost I-4 3.73 12,590 — 7,500 —
2.7L EcoBoost V63 3.73 12,745 — 7,500 —
3.0L EcoBoost V6 (Raptor) 4.27 11,465 — — 5,510
2019-2023 Ford Ranger
Body Style
Drive Axle Ratio Maximum GCWR (lbs.) Maximum Trailer Weight (lbs.)
SuperCab Chassis 2WD 3.73 12,500 7,500
SuperCab
2WD 3.73 12,150 7,500
4WD 3.73 12,400 7,500
SuperCrew Cab
2WD 3.73 12,250 7,500
4WD 3.73 12,500 7,500
2011 Ford Ranger
Trailer Towing Table (Regular Cab)
Cab Style Engine / Transmission Maximum GCWR (lbs.) Maximum Trailer Weight (lbs.)
Regular Cab Short Wheel Base 2.3L Manual 4800 1520
Regular Cab Short Wheel Base 2.3L Automatic 5500 2180
Regular Cab Long Wheel Base 2.3L Manual 4800 1500
Regular Cab Long Wheel Base 2.3L Automatic 5500 2160
Regular Cab Long Wheel Base 4.0L 9500 5940
Trailer Towing Table (SuperCab 4×2)
Cab Style Engine / Transmission Maximum GCWR (lbs) Maximum Trailer Weight (lbs)
SuperCab 2-Door Payload Package 1 (No Jump Seat) 2.3L Manual 4800 1380
SuperCab 2-Door Payload Package 1 (No Jump Seat) 2.3L Automatic 5500 2040
SuperCab 2-Door Payload Package 1 (No Jump Seat) 4.0L Manual 7000 3360
SuperCab 2-Door Payload Package 1 (No Jump Seat) 4.0L Automatic 9500 5820
SuperCab 4-Door Payload Package 1 (No Jump Seat) 2.3L Manual 4800 1300
SuperCab 4-Door Payload Package 1 (No Jump Seat) 2.3L Automatic 5500 1960
SuperCab 4-Door Payload Package 1 (No Jump Seat) 4.0L Manual 7000 3280
SuperCab 4-Door Payload Package 1 (No Jump Seat) 4.0L Automatic 9500 5740
SuperCab 2-Door Payload Package 1 (With Jump Seat) 2.3L Manual 4800 1340
SuperCab 2-Door Payload Package 1 (With Jump Seat) 2.3L Automatic 5500 2020
SuperCab 2-Door Payload Package 1 (With Jump Seat) 4.0L Manual 7000 3340
SuperCab 2-Door Payload Package 1 (With Jump Seat) 4.0L Automatic 9500 5780
Trailer Towing Table (SuperCab 4×4)
SuperCab 4×4 4.0L Manual 7000 3120
SuperCab 4×4 4.0L Automatic 9500 5580
SuperCab 4×4 4.0L Manual (With Jump Seat) 7000 3080
SuperCab 4×4 4.0L Automatic (With Jump Seat) 9500 5540
SuperCab 4×4 4.0L Manual (4-Door) 7000 3040
SuperCab 4×4 4.0L Automatic (4-Door) 9500 5500
SuperCab 4×4 4.0L Manual (4-Door With Jump Seat) 7000 3000
SuperCab 4×4 4.0L Automatic (4-Door With Jump Seat) 9500 5460
2010 Ford Ranger
Cab Style Engine / Transmission Rear Axle Ratio Maximum GCWR (lbs.) Maximum Trailer Weight (lbs.)
Regular Cab Short Wheel Base 2.3L Manual 3.73 4800 1540
Regular Cab Short Wheel Base 2.3L Automatic 4.10 5500 2200
Regular Cab Long Wheel Base 2.3L Manual 3.73 4800 1500
Regular Cab Long Wheel Base 2.3L Automatic 4.10 5500 2160
Regular Cab Long Wheel Base 4.0L 3.55 9500 5940
Trailer Towing Table (SuperCab 4×2 – Payload Package 1)
Cab Style Package Engine / Transmission Rear Axle Ratio Maximum GCWR (lbs.) Maximum Trailer Weight (lbs.)
SuperCab 4×2 2-Door No Jump Seat 2.3L Manual 4.10 4800 1340
SuperCab 4×2 2-Door No Jump Seat 2.3L Automatic 4.10 5500 2020
SuperCab 4×2 2-Door No Jump Seat 4.0L Manual 3.55 7000 3340
SuperCab 4×2 2-Door No Jump Seat 4.0L Automatic 3.55 9500 5780
SuperCab 4×2 4-Door No Jump Seat 2.3L Manual 4.10 4800 1260
SuperCab 4×2 4-Door No Jump Seat 2.3L Automatic 4.10 5500 1920
SuperCab 4×2 4-Door No Jump Seat 4.0L Manual 3.55 7000 3260
SuperCab 4×2 4-Door No Jump Seat 4.0L Automatic 3.55 9500 5700
SuperCab 4×2 2-Door With Jump Seat 2.3L Manual 4.10 4800 1320
SuperCab 4×2 2-Door With Jump Seat 2.3L Automatic 4.10 5500 1980
SuperCab 4×2 2-Door With Jump Seat 4.0L Manual 3.55 7000 3300
SuperCab 4×2 2-Door With Jump Seat 4.0L Automatic 3.55 9500 5760
Trailer Towing Table (SuperCab 4×2 Sport)
Cab Style Package Engine / Transmission Rear Axle Ratio Maximum GCWR (lbs) Maximum Trailer Weight (lbs)
SuperCab 4×2 Sport 2-Door No Jump Seat 4.0L Manual 3.55 7000 3240
SuperCab 4×2 Sport 2-Door No Jump Seat 4.0L Automatic 3.55 9500 5700
SuperCab 4×2 Sport 4-Door No Jump Seat 4.0L Manual 3.55 7000 3160
SuperCab 4×2 Sport 4-Door No Jump Seat 4.0L Automatic 3.55 9500 5620
SuperCab 4×2 Sport 2-Door With Jump Seat 4.0L Manual 3.55 7000 3220
SuperCab 4×2 Sport 2-Door With Jump Seat 4.0L Automatic 3.55 9500 5660
SuperCab 4×4 2-Door No Jump Seat 4.0L Manual All 7000 3120
SuperCab 4×4 2-Door No Jump Seat 4.0L Automatic All 9500 5580
SuperCab 4×4 4-Door No Jump Seat 4.0L Manual All 7000 3040
SuperCab 4×4 4-Door No Jump Seat 4.0L Automatic All 9500 5500
SuperCab 4×4 2-Door With Jump Seat 4.0L Manual All 7000 3080
SuperCab 4×4 2-Door With Jump Seat 4.0L Automatic All 9500 5540
Trailer Towing Table (SuperCab 4×4 Sport)
SuperCab 4×4 Sport 2-Door No Jump Seat 4.0L Manual All 7000 3120
SuperCab 4×4 Sport 2-Door No Jump Seat 4.0L Automatic All 9500 5580
SuperCab 4×4 Sport 4-Door No Jump Seat 4.0L Manual All 7000 3040
SuperCab 4×4 Sport 4-Door No Jump Seat 4.0L Automatic All 9500 5500
2009 Ford Ranger
Trailer Towing Table (4×2 Manual Transmission)
Cab Style Engine Rear Axle Ratio Maximum GCWR (lbs.) Maximum Trailer Weight (lbs.)
Regular Cab 4×2 w/6′ box 2.3L All 4800 1580
Regular Cab 4×2 w/6′ box 2.3L Sport All 4800 1520
Regular Cab 4×2 w/7′ box 2.3L All 4800 1540
SuperCab 4×2 2.3L All 4800 1420
SuperCab 4×2 4.0L All 7000 3400
SuperCab 4×2 4.0L Sport All 7000 3220
Trailer Towing Table (4×4 Manual Transmission)
Regular Cab 4×4 w/6′ box 4.0L All 7000 3280
Regular Cab 4×4 w/7′ box 4.0L All 7000 3240
SuperCab 4×4 4.0L All 7000 3140
Trailer Towing Table (4×2 Automatic Transmission)
Regular Cab 4×2 w/6′ box 2.3L All 5500 2240
Regular Cab 4×2 w/6′ box 2.3L Sport All 5500 1960
Regular Cab 4×2 w/7′ box 2.3L All 5500 2220
SuperCab 4×2 2.3L All 5500 2080
SuperCab 4×2 4.0L All 9500 5860
SuperCab 4×2 4.0L Sport All 9500 5680
Trailer Towing Table (4×4 Automatic Transmission)
Regular Cab 4×4 w/6′ box 4.0L All 9500 5740
Regular Cab 4×4 w/7′ box 4.0L All 9500 5680
SuperCab 4×4 4.0L All 9500 5600
2008 Ford Ranger
Regular Cab 4×2 (6’ box) 2.3L All 4800 1580
Regular Cab 4×2 (6’ box) 2.3L Sport All 4800 1520
Regular Cab 4×2 (6’ box) 3.0L All 6000 2640
Regular Cab 4×2 (6’ box) 3.0L* Sport All 6000 2580
Regular Cab 4×2 (7’ box) 2.3L All 4800 1540
Regular Cab 4×2 (7’ box) 3.0L All 6000 2600
SuperCab 4×2 3.0L All 6000 2460
SuperCab 4×2 3.0L Sport All 6000 2280
Regular Cab 4×4 (6’ box) 3.0L All 6000 2360
Regular Cab 4×4 (6’ box) 4.0L All 7000 3280
Regular Cab 4×4 (7’ box) 3.0L All 6000 2300
Regular Cab 4×4 (7’ box) 4.0L All 7000 3240
Regular Cab 4×2 (6’ box) 2.3L All 5500 2240
Regular Cab 4×2 (6’ box) 2.3L Sport All 5500 1960
Regular Cab 4×2 (6’ box) 3.0L All 6000 2600
Regular Cab 4×2 (6’ box) 3.0L Sport All 6000 2520
Regular Cab 4×2 (7’ box) 2.3L All 5500 2220
Regular Cab 4×2 (7’ box) 3.0L All 6000 2560
SuperCab 4×2 3.0L All 6000 2420
SuperCab 4×2 3.0L Sport All 6000 2240
SuperCab 4×2 4.0L All 9500 6000
Regular Cab 4×4 (6’ box) 3.0L All 6000 2320
Regular Cab 4×4 (6’ box) 4.0L All 9500 5740
Regular Cab 4×4 (7’ box) 3.0L All 6000 2260
Regular Cab 4×4 (7’ box) 4.0L All 9500 5680
2007 Ford Ranger
Regular Cab 4×2 (6’ box) 3.0L Edge All 6000 2500
Regular Cab 4×2 (7’ box) 2.3L All 4800 1520
Regular Cab 4×2 (7’ box) 3.0L All 6000 2580
SuperCab 4×2 2.3L All 4800 1400
SuperCab 4×2 3.0L Edge All 6000 2340
SuperCab 4×2 4.0L All 7000 3380
SuperCab 4×2 4.0L Edge All 7000 3260
Regular Cab 4×4 (6’ box) 4.0L All 7000 3260
Regular Cab 4×4 (7’ box) 4.0L All 7000 3200
SuperCab 4×4 4.0L (without FX4 package) All 7000 3080
SuperCab 4×4 4.0L (with FX4 package) All 7000 2740
Regular Cab 4×2 (6’ box) 3.0L* Edge All 6000 2420
Regular Cab 4×2 (7’ box) 2.3L All 5500 2180
Regular Cab 4×2 (7’ box) 3.0L All 6000 2540
Regular Cab 4×2 (7’ box) 4.0L All 9500 6000
SuperCab 4×2 2.3L All 5500 2100
SuperCab 4×2 3.0L Edge All 6000 2280
SuperCab 4×2 4.0L Edge All 9500 5720
Regular Cab 4×4 (6’ box) 3.0L All 6000 2300
Regular Cab 4×4 (6’ box) 4.0L All 9500 5720
Regular Cab 4×4 (7’ box) 3.0L All 6000 2220
Regular Cab 4×4 (7’ box) 4.0L All 9500 5640
SuperCab 4×4 4.0L (without FX4 package) All 9500 5560
SuperCab 4×4 4.0L (with FX4 package) All 9500 5220
2006 Ford Ranger
Regular Cab 4×2 w/6′ box 2.3L All 4,800 1,580
Regular Cab 4×2 w/6′ box 3.0L All 6,000 2,660
Regular Cab 4×2 w/6′ box 3.0L Edge All 6,000 2,500
Regular Cab 4×2 w/7′ box 2.3L All 4,800 1,560
Regular Cab 4×2 w/7′ box 3.0L All 6,000 2,600
SuperCab 4×2 2.3L All 4,800 1,440
SuperCab 4×2 3.0L All 6,000 2,480
SuperCab 4×2 3.0L Edge All 6,000 2,340
SuperCab 4×2 4.0L All 7,000 3,400
SuperCab 4×2 4.0L Edge All 7,000 3,280
Regular Cab 4×4 w/6′ box 3.0L All 6,000 2,340
Regular Cab 4×4 w/6′ box 4.0L All 7,000 3,280
Regular Cab 4×4 w/7′ box 3.0L All 6,000 2,300
Regular Cab 4×4 w/7′ box 4.0L All 7,000 3,220
SuperCab 4×4 4.0L All 7,000 3,120
SuperCab 4×4 4.0L FX4 All 7,000 2,840
Regular Cab 4×2 w/6′ box 2.3L All 5,500 2,260
Regular Cab 4×2 w/6′ box 3.0L All 6,000 2,620
Regular Cab 4×2 w/6′ box 3.0L Edge All 6,000 2,460
Regular Cab 4×2 w/7′ box 2.3L All 5,500 2,220
Regular Cab 4×2 w/7′ box 3.0L All 6,000 2,560
Regular Cab 4×2 w/7′ box 4.0L All 9,500 6,000
SuperCab 4×2 2.3L All 5,500 1,380
SuperCab 4×2 3.0L All 6,000 2,440
SuperCab 4×2 3.0L Edge All 6,000 2,300
SuperCab 4×2 4.0L All 9,500 5,860
SuperCab 4×2 4.0L Edge All 9,500 5,720
Regular Cab 4×4 w/6′ box 3.0L All 6,000 2,320
Regular Cab 4×4 w/6′ box 4.0L All 9,500 5,740
Regular Cab 4×4 w/7′ box 3.0L All 6,000 2,260
Regular Cab 4×4 w/7′ box 4.0L All 9,500 5,680
SuperCab 4×4 4.0L All 9,500 5,580
SuperCab 4×4 4.0L FX4 All 9,500 5,300
2005 Ford Ranger
Regular Cab 4×2 6′ Box 2.3L All 4,800 1,600
Regular Cab 4×2 6′ Box 3.0L All 6,000 2,640
Regular Cab 4×2 6′ Box 3.0L Edge All 6,000 2,500
Regular Cab 4×4 6′ Box 3.0L All 6,000 2,340
Regular Cab 4×4 6′ Box 4.0L All 7,000 3,280
Regular Cab 4×4 7′ Box 3.0L All 6,000 2,280
Regular Cab 4×4 7′ Box 4.0L All 7,000 3,220
SuperCab 4×4 4.0L (without FX4) All 7,000 3,100
SuperCab 4×4 4.0L FX4 All 7,000 2,760
Regular Cab 4×2 6′ Box 2.3L All 5,500 2,260
Regular Cab 4×2 6′ Box 3.0L All 6,000 2,600
Regular Cab 4×2 6′ Box 3.0L Edge All 6,000 2,460
Regular Cab 4×2 7′ Box 2.3L All 5,500 2,200
Regular Cab 4×2 7′ Box 3.0L All 6,000 2,540
SuperCab 4×2 3.0L All 6,000 2,420
SuperCab 4×2 4.0L Edge All 9,500 5,740
Regular Cab 4×4 6′ Box 3.0L All 6,000 2,300
Regular Cab 4×4 6′ Box 4.0L All 9,500 5,740
Regular Cab 4×4 7′ Box 3.0L All 6,000 2,240
Regular Cab 4×4 7′ Box 4.0L All 9,500 5,660
SuperCab 4×4 4.0L (without FX4) All 9,500 5,580
SuperCab 4×4 4.0L FX4 All 9,500 5,220
2004 Ford Ranger
Regular Cab 4×2 6′ Box 2.3L All 4,800 1,580
Regular Cab 4×2 6′ Box 3.0L All 6,000 2,660
Regular Cab 4×2 6′ Box 3.0L Edge All 6,000 2,520
Regular Cab 4×2 7′ Box 2.3L All 4,800 1,520
Regular Cab 4×2 7′ Box 3.0L All 6,000 2,580
SuperCab 4×2 2.3L All 4,800 1,420
SuperCab 4×2 3.0L Edge All 6,000 2,400
SuperCab 4×2 4.0L Edge All 7,000 3,320
Regular Cab 4×4 6′ Box 4.0L All 7,000 3,260
Regular Cab 4×4 7′ Box 4.0L All 7,000 3,200
SuperCab 4×4 4.0L FX4 All 7,000 2,740
Regular Cab 4×2 6′ Box 2.3L All 5,500 2,240
Regular Cab 4×2 6′ Box 3.0L All 6,000 2,620
Regular Cab 4×2 6′ Box 3.0L Edge All 6,000 2,480
Regular Cab 4×2 7′ Box 2.3L All 5,500 2,180
Regular Cab 4×2 7′ Box 4.0L All 9,500 5,980
SuperCab 4×2 3.0L Edge All 6,000 2,360
Regular Cab 4×4 6′ Box 4.0L All 9,500 5,720
SuperCab 4×4 4.0L (without FX4) All 9,500 5,560
SuperCab 4×4 4.0L FX4 All 9,500 5,200
2002-2003 Ford Ranger
Regular Cab 4×2 2.3L All 4,800 1,660
Regular Cab 4×2 3.0L All 6,000 2,660
Regular Cab 4×2 3.0L Torsion Bar Suspension All 6,000 2,540
Regular Cab 4×2 4.0L All 7,000 3,580
Regular Cab 4×2 4.0L Torsion Bar Suspension All 7,000 3,460
Regular Cab 4×2 2.3L All 4,800 1,600
SuperCab 4×2 2.3L All 4,800 1,480
SuperCab 4×2 3.0L Torsion Bar Suspension All 6,000 2,320
SuperCab 4×2 4.0L Torsion Bar Suspension All 7,000 3,260
Regular Cab 4×4 3.0L All 6,000 2,380
Regular Cab 4×4 4.0L All 7,000 3,320
Regular Cab 4×4 3.0L All 6,000 2,340
SuperCab 4×4 3.0L All 6,000 2,220
SuperCab 4×4 4.0L All 7,000 3,140
SuperCab 4×4 4.0L FX4 Package All 7,000 2,720
Regular Cab 4×2 2.3L All 5,500 2,260
Regular Cab 4×2 3.0L All 7,500 4,120
Regular Cab 4×2 3.0L Torsion Bar Suspension All 7,500 4,000
Regular Cab 4×2 4.0L All 9,500 6,040
Regular Cab 4×2 4.0L Torsion Bar Suspension All 9,500 5,920
SuperCab 4×2 3.0L All 7,500 3,940
SuperCab 4×2 3.0L Torsion Bar Suspension All 7,500 3,780
Regular Cab 4×4 3.0L All 7,500 3,860
Regular Cab 4×4 4.0L All 9,500 5,780
SuperCab 4×4 3.0L All 7,500 3,680
SuperCab 4×4 4.0L All 9,500 5,600
SuperCab 4×4 4.0L FX4 Package All 9,500 5,180
2001 Ford Ranger
SuperCab 4×2 3.0L All 7,500 3,920
SuperCab 4×2 4.0L All 9,500 5,880
SuperCab 4×2 4.0L Torsion Bar Suspension All 9,500 5,720
2000 Ford Ranger
Regular Cab 4×2 2.5L 3.73 4,800 1,580
Regular Cab 4×2 2.5L 4.10 4,800 1,580
Regular Cab 4×2 3.0L 3.73 6,000 2,660
Regular Cab 4×2 3.0L Torsion Bar Suspension 4.10 6,000 2,600
Regular Cab 4×2 4.0L 3.55 7,000 3,600
SuperCab 4×2 2.5L 3.73 4,800 1,360
SuperCab 4×2 2.5L 4.10 4,800 1,360
SuperCab 4×2 3.0L 3.73 6,000 2,460
SuperCab 4×2 4.0L 3.55 7,000 3,400
Regular Cab 4×4 3.0L 3.73 6,000 2,400
Regular Cab 4×4 3.0L 4.10 6,000 2,400
Regular Cab 4×4 4.0L 3.73 7,000 3,340
Regular Cab 4×4 4.0L 4.10 7,000 3,340
SuperCab 4×4 3.0L 3.73 6,000 2,200
SuperCab 4×4 3.0L 4.10 6,000 2,200
SuperCab 4×4 4.0L 3.73 7,000 3,160
SuperCab 4×4 4.0L 4.10 7,000 3,160
Regular Cab 4×2 2.5L 4.10 5,500 2,180
Regular Cab 4×2 3.0L 3.73 7,500 4,120
Regular Cab 4×2 3.0L Torsion Bar Suspension 4.10 7,500 4,060
Regular Cab 4×2 4.0L 3.55 9,500 6,060
SuperCab 4×2 3.0L 3.73 7,500 3,920
SuperCab 4×2 4.0L 3.55 9,500 5,860
Regular Cab 4×4 3.0L 3.73 7,500 3,860
Regular Cab 4×4 3.0L 4.10 8,000 4,360
Regular Cab 4×4 4.0L 3.73 9,500 5,800
Regular Cab 4×4 4.0L 4.10 9,500 5,800
SuperCab 4×4 3.0L 3.73 7,500 3,660
SuperCab 4×4 3.0L 4.10 8,000 4,160
SuperCab 4×4 4.0L 3.73 9,500 5,620
SuperCab 4×4 4.0L 4.10 9,500 5,620
1999 Ford Ranger
Regular Cab 4×2 2.5L 3.73 4,800 1,600
Regular Cab 4×2 2.5L 4.10 4,800 1,600
Regular Cab 4×2 3.0L 3.73 6,000 2,720
Regular Cab 4×2 4.0L 3.55 7,000 3,660
SuperCab 4×2 2.5L 3.73 4,800 1,440
SuperCab 4×2 2.5L 4.10 4,800 1,440
SuperCab 4×2 3.0L 3.73 6,000 2,580
SuperCab 4×2 4.0L 3.55 7,000 3,520
Regular Cab 4×4 4.0L 3.73 7,000 3,360
Regular Cab 4×4 4.0L 4.10 7,000 3,360
SuperCab 4×4 3.0L 3.73 6,000 2,240
SuperCab 4×4 3.0L 4.10 6,000 2,240
SuperCab 4×4 4.0L 3.73 7,000 3,200
SuperCab 4×4 4.0L 4.10 7,000 3,200
Regular Cab 4×2 2.5L 4.10 5,500 2,240
Regular Cab 4×2 3.0L 3.73 7,500 4,000
Regular Cab 4×2 4.0L 3.55 9,500 6,000
SuperCab 4×2 3.0L 3.73 7,500 4,000
SuperCab 4×2 4.0L 3.55 9,500 5,980
Regular Cab 4×4 4.0L 3.73 9,500 5,820
Regular Cab 4×4 4.0L 4.10 9,500 5,820
SuperCab 4×4 3.0L 3.73 7,500 3,700
SuperCab 4×4 3.0L 4.10 8,000 4,200
SuperCab 4×4 4.0L 3.73 9,500 5,660
SuperCab 4×4 4.10 9,500 5,660
1998 Ford Ranger
Regular Cab 4×2 2.5L 3.45 Not recommended for trailer towing Not recommended
Regular Cab 4×2 3.0L 3.45 5,000 1,740
Regular Cab 4×2 3.0L 3.73 6,000 2,700
Regular Cab 4×2 4.0L 3.08 5,000 1,660
Regular Cab 4×2 4.0L 3.55 7,000 3,640
Regular Cab 4×2 (Splash or Special Suspension) 2.5L 3.73 4,800 1,500
Regular Cab 4×2 (Splash or Special Suspension) 3.0L 3.73 5,400 2,000
Regular Cab 4×2 (Splash or Special Suspension) 4.0L 3.08 5,000 1,580
Regular Cab 4×2 (Splash or Special Suspension) 4.0L 3.55 5,500 2,000
SuperCab 4×2 2.5L 3.73 4,800 1,380
SuperCab 4×2 3.0L 3.45 5,000 1,540
SuperCab 4×2 3.0L 3.73 6,000 2,500
SuperCab 4×2 4.0L 3.08 5,000 1,400
SuperCab 4×2 (Splash or Special Suspension) 3.0L 3.73 5,600 2,000
SuperCab 4×2 (Splash or Special Suspension) 4.0L 3.08 5,000 1,400
SuperCab 4×2 (Splash or Special Suspension) 4.0L 3.55 5,600 2,000
Regular Cab 4×4 3.0L 3.73 6,000 2,380
Regular Cab 4×4 4.0L 3.27 6,000 2,000
Regular Cab 4×4 (Splash) 3.0L 3.73 6,000 2,360
Regular Cab 4×4 (Splash) 4.0L 3.27 6,000 2,000
Regular Cab 4×4 (Splash) 4.0L 3.73 7,000 3,300
SuperCab 4×4 3.0L 3.73 6,000 2,220
SuperCab 4×4 4.0L 3.27 6,000 2,000
SuperCab 4×4 4.0L 3.73 7,000 3,180
SuperCab 4×4 (Splash) 3.0L 3.73 6,000 2,200
SuperCab 4×4 (Splash) 4.0L 3.27 6,000 2,000
SuperCab 4×4 (Splash) 4.0L 3.73 7,000 3,140
Regular Cab 4×2 2.5L 4.10 5,500 2,220
Regular Cab 4×2 3.0L 3.45 7,000 3,660
Regular Cab 4×2 4.0L 3.08 6,000 2,600
Regular Cab 4×2 (Splash or Special Suspension) 2.5L 3.73 5,400 2,000
Regular Cab 4×2 (Splash or Special Suspension) 4.0L 3.08 5,500 2,000
SuperCab 4×2 3.0L 3.73 7,500 3,960
SuperCab 4×2 4.0L 3.08 6,000 2,380
SuperCab 4×2 4.0L 3.55 9,500 5,900
SuperCab 4×2 (Splash or Special Suspension) 4.0L 3.08 5,700 2,000
SuperCab 4×2 (Splash or Special Suspension) 4.0L 3.55 5,700 2,000
Regular Cab 4×4 3.0L 3.73 7,500 3,840
Regular Cab 4×4 3.0L 4.10 8,000 4,340
Regular Cab 4×4 4.0L 3.27 7,500 3,800
Regular Cab 4×4 (Splash) 3.0L 3.73 7,500 3,820
Regular Cab 4×4 (Splash) 3.0L 4.10 8,000 4,320
Regular Cab 4×4 (Splash) 4.0L 3.27 7,500 3,760
Regular Cab 4×4 (Splash) 4.0L 3.73 9,500 5,760
SuperCab 4×4 3.0L 3.73 7,500 3,680
SuperCab 4×4 3.0L 4.10 8,000 4,180
SuperCab 4×4 4.0L 3.27 7,500 3,640
SuperCab 4×4 4.0L 3.73 9,500 5,640
SuperCab 4×4 (Splash) 3.0L 3.73 7,500 3,660
SuperCab 4×4 (Splash) 3.0L 4.10 8,000 4,160
SuperCab 4×4 (Splash) 4.0L 3.27 7,500 3,600
SuperCab 4×4 (Splash) 4.0L 3.73 9,500 5,600
1995-1997 Ford Ranger
Trailer Towing Table – 4×2 Manual Transmission
Engine (EFI) Rear Axle Ratio Maximum GCWR (lbs.) Trailer Weight Range (lbs.)
Regular Cab 4×2
2.3L 3.45 Not recommended 0
2.3L 3.75 4800 lbs. 1,600 lbs.
3.0L 3.45 5,000 lbs. 1,800 lbs.
3.0L 3.73 6,000 lbs. 2,800 lbs.
4.0L 3.08 7,000 lbs. 3,700 lbs.
4.0L 3.55 7,000 lbs. 3,700 lbs.
2.3L 3.73 4,800 lbs. 1,500 lbs.
3.0L 3.73 5,300 lbs. 2,000 lbs.
4.0L 3.08 5,000 lbs. 1,600 lbs.
4.0L 3.55 5,400 lbs. 2,000 lbs.
Super Cab 4×2
2.3L 3.73 4,800 lbs. 1,300 lbs.
Trailer Towing Table – 4×4 Manual Transmission
Regular Cab 4×4
2.3L 4.10 4,800 lbs. 1,300 lbs.
3.0L 3.73 6,000 lbs. 2,400 lbs.
4.0L 3.27 6,000 lbs. 2,000 lbs.
4.0L 3.73 7,000 lbs. 3,400 lbs.
3.0L 3.73 6,000 lbs. 2,500 lbs.
4.0L 3.27 6,000 lbs. 2.000 lbs.
Super Cab 4×4
3.0L 3.73 6,000 lbs. 2,100 lbs.
4.0L 3.73 7,000 lbs. 3,000 lbs.
Trailer Towing Table – 4×2 Automatic Transmission
Regular Cab 4×2
2.3L 3.73 5,500 lbs. 2,300 lbs.
3.0L 3.45 7,000 lbs. 3,700 lbs.
3.0L 3.73 7,500 lbs. 4,000 lbs.
4.0L 3.08 6,000 lbs. 2,700 lbs.
4.0L 3.55 9,500 lbs. 6,000 lbs.
2.3L 3.73 5,300 lbs. 2,000 lbs.
3.0L 3.73 5,400 lbs. 2,000 lbs.
4.0L 3.08 5,400 lbs. 2,000 lbs.
Trailer Towing Table – 4×4 Automatic Transmission
Regular Cab 4×4
3.0L 3.73 7,500 lbs. 3,900 lbs.
3.0L 4.10 8,000 lbs. 4,400 lbs.
4.0L 3.27 7,500 lbs. 3,800 lbs.
4.0L 3.73 9,500 lbs. 5,800 lbs.
Super Cab 4×4 (Splash)
1993-1994 Ford Ranger
Maximum Trailer Towing Weights
Engine Axle Ratio GCWR Max. (lbs.) Regular Cab
Trailer Weight
(lbs.)
SuperCab
Trailer Weight
(lbs.)
4×2 4×4 4×2 4×4
2.3L EFI I-4 / 4-Speed Auto. 3.73 5,500 2,300 — — —
3.0L EFI V-6 / 4-Speed Auto. 3.45 7,000 3,700 — 3,500 —
3.73 7,500 4,000 4,000 4,000 3,800
4.10 8,000 — 4,500 — 4,300
4.0L EFI V-6 / 4-Speed Auto. 3.08 6,000 2,700 — 2,400 —
3.27 7,500 — 3,900 — 3,600
3.55 9,500 6,000 — 5,900 —
3.73 9,500 — 5,900 — 5,600
2.3L EFI I-4 / 5-Speed Man. 3.73 4,800 1,600 — 1,300 —
4.10 4,800 — 1,300 — —
3.0L EFI V-6 / 5-Speed Man. 3.45 5,000 1,800 1,500 1,500 1,300
3.73 6,000 2,800 2,500 2,500 2,300
4.0L EFI V-6 / 5-Speed Man. 3.08 5,000 1,700 — 1,400 —
3.27 6,000 — 2,000 — 2,000
3.55 7,000 3,700 — 3,400 —
3.73 7,000 — 3,400 — 3,200
1992 Ford Ranger
Trailer Weight
(lbs.)
SuperCab
Trailer Weight
(lbs.)
4×2 4×4 4×2 4×4
2.3L EFI I-4 / 4-Speed Auto. 4.10 6,000 2,700 — — —
2.9L EFI V-6 / 4-Speed Auto. 3.73 7,500 — 3,800 — 3,600
4.10 8,000 — 4,300 — 4,100
3.0L EFI V-6 / 4-Speed Auto. 3.45 7,000 3,700 — 3,400 —
3.73 7,500 4,200 — 3,900 —
4.0L EFI V-6 / 4-Speed Auto. 3.08 6,000 2,600 — 2,300 —
3.27 7,500 — 3,800 — 3,500
3.55 9,500 6,100 — 5,800 —
3.73 9,500 — 5,800 — 5,500
2.3L EFI I-4 / 5-Speed Man. 3.73 4,800 1,500 — 1,300 —
4.10 4,800 — 1,200 — —
2.9L EFI V-6 / 5-Speed Man. 3.55 5,000 — 1,400 — 1,300
3.73 6,000 — 2,400 — 2,100
3.0L EFI V-6 / 5-Speed Man. 3.45 5,000 1,700 — 1,400 —
3.73 6,000 2,700 — 2,400 —
4.0L EFI V-6 / 5-Speed Man. 3.08 5,000 1,600 — 1,400 —
3.27 6,000 — 2,300 — 2,100
3.55 6,000 — 2,300 — 2,100
3.55 7,000 3,600 — 3,400 —
3.73 7,000 — 3,300 — 3,100
1991 Ford Ranger
Ford’s 1991 Ranger sales brochure did not list trailer towing capacities. I could not locate a copy of the 1991 Ford Ranger owner’s manual or the 1991 Ford towing guide. Until I do, I would suggest looking at the 1990 and 1992 trailer weight limits. I think you will find similar ratings between those years to estimate what the limits would be for 1991.
1990 Ford Ranger
(lbs.)
Regular Cab
(lbs.)
SuperCab
(lbs.)
4×2 4×4 4×2 4×4
2.3L EFI I-4 4.10 6,000 2,900 — — —
2.9L EFI V-6 3.45 7,500 4,400 — 4,100 —
3.73 8,000 4,900 4,500 4,600 4,300
4.10 8,500 — 5,000 — 4,800
3.0L EFI V-6 3.45 7,500 — — — —
3.73 8,000 — — — —
4.10 8,500 — — — —
4.0L EFI V-6 3.08 6,000 2,800 — 2,400 —
3.27 7,500 — — — —
3.55 8,000 — 4,400 — 4,100
3.55 8,500 — — — —
3.55 9,500 6,300 — 5,900 —
3.73 8,500 — — — —
1989 Ford Ranger
Years Configuration Engine Axle Ratio Max Trailer Weight (lbs.)
1989 Regular Cab 2WD Properly Equipped Ranger N/A 5,400
1989 Regular Cab 4WD Properly Equipped Ranger N/A 5,100
1988 Ford Ranger
Years Configuration Engine Axle Ratio Max Trailer Weight (lbs)
1988 Regular Cab 4×2 Properly Equipped Ranger N/A 5,500
Ford noted that 4WD and SuperCab models had lower towing ratings.
1987 Ford Ranger
1987 Regular Cab 4×2 Properly Equipped Ranger 4.10 5,600
1987 Regular Cab 4×4 Properly Equipped Ranger 4.10 5,300
Ford noted that SuperCab models had lower towing ratings.
1986 Ford Ranger
1986 Regular Cab 4×2 Properly Equipped Ranger 3.73 5,100
1986 Regular Cab 4×4 Properly Equipped Ranger 4.10 5,400
1984-1985 Ford Ranger
Years Configuration Engine Transmission Axle Ratio Max Trailer Weight (lbs.)
1984-1985 Ranger 4×2 2.8L V6 Automatic 3.73 5,100
1983 Ford Ranger
1983 Ranger 4×2 2.8L V6 Automatic 3.73 4,500
Related Articles
Ford Towing Guides
Ford Ranger Payloads
Ford Ranger Specifications
Towing Trailers
Wiring For Trailer Lights
Securing Your Rig On Your Trailer
RedArc Tow-Pro Liberty Brake Controller
All-New Ford Ranger Uses Radar to Make Towing Easier
Trailer Tire Wear
About The Author
