PlumCrazy's 88 SuperCab 2.3T Build
Featured Build Threads
Double checked my wastegate plumbing and all is well. Picked up a hand held vacuum/pressure pump that is actually pretty slick.
From what I can see so far...I had maybe a little too much preload (5-6mm) and the rod configuration had the actuator in a slight bind that seemed to not allow any movement until about 12psi and not fully open until 20 psi. My next fear is that even after I optimize the rod preload and routing....that this wastegate may just be inadequate. It only opens 3/8" and its only a 1" hole or so. I have read people port the hole for more flow, so that may be something I look into.
Wastegate actuator test video
I got it to a point where it has visual movement at 9psi and full open by 15psi which seams high still after confirming with the place I purchased it that it is supposed to be a 7psi actuator. I also tested a few factory actuators and they seem to be similar though. so maybe the Harbor Freight gauge isn't accurate? The company also volunteered another actuator to play with and it should be here tomorrow. Hopefully it comes with new snap ring too.....becuase I sent mine into orbit when it slipped off and was not able to confirm re-entry.
I was able to drive the truck a bit today. Put about 75 miles on it over all.
Boost control is manageable now. If I roll into with some sense it will maintain at 13-14psi. If I let loose and flat foot it...it will head to 20. I set the boost safety to 15ish and have only hit it a time or two.
Valve cover leak went from bad, to good after snugging up the bolts....then to not ideal... Now leaking at the front with tight bolts.
So catch can is probably in the future after resealing the valve cover.
Looks cool at least.
A self draining catch can with atmospheric vent would work pretty good, it's been on my list of things to make as everything available aftermarket is manual drain and I'm too lazy for that...
I'm probably doing something wrong... I can get to the page with a pic of the video. Even goes full size with a start button in the center, but nothing happens.
It's hosted on Google drive, it takes a little bit to load completely.
Did you actually see the video? I waited about 2 minutes and nothing. When I pull up the "info" I get the following, which to me means it's just a picture....
PS I'm using a pixel 10pro with the latest updates. DuckDuckGo or FF for browser.
Update; I got it to work in FF.
They work for me, but they are shared from my drive. I could upload to YouTube I suppose.
Yes. When I go to the link it reopens in Google photos as the video
Pixel 9 pro in firefox
I added YouTube links to all the video posts.
Decided I should probably figure out some sort of filter and a blow-off valve after raw dogging around for 250 miles...
Scooped up well used TurboXS blow off and little bit of 1.25" stainless tube on ebay
Made a bung out of the tube and TIGd it on
Got a 135* boot and a some left over stainless pipe and it all kinda fell together pretty easy. FYI a lot of K&N filters are clearance prices on Advance Autos website.
I trimmed back the boot using some scrap tube as a guide
Mocked up an airbox/heat shield shape with a bit of filler wire
Upcycled some aluminum
Just need to get some clamps for the boot and probably weld a support tab onto the pipe to hold the filter up off of the head shield
Got a little mixed up on my cut lines/vs bend lines and cut 2" too much off on the important side...so I compromised and just bent a 45* angle to get as much height back as I could, but I may redo this whole setup differently some day. Ideally I should move the battery to the driver side and make an air box that can pull cool air around the headlight or potentially go back to a stock style airbox with a duct up to the rad support again.
Well f*** me does the aluminum valve cover not come off without a fight. Loosened the cam bolt and slid the pulley forward 3/8", jacked up the trans until it hit the tunnel as well as jacked up the cab as much as the mounts allowed.
The gasket appears to have split at the recess in the front cam tower.
Anyways...tapped the valve cover to accept a -4 fitting while I wait for the allegedly best 2.3/2.5 gasket out there to show up.
I think I will replace the cam seal and potentially valve seals like I should have before the engine went in. It will make the valve cover easier to install at a minimum.
I'm also looking at ways to use the factory air box instead of an open cone filter.
it idles like an angry massey.
It's no where as clean as yours but this is what I did to use the stock filter box, I found a 2.9 from I think '88-89 before they went MAF at the junkyard and took the top and hose and made it work, if you look close you will notice I spliced the hose with a hose clamp over the middle, on the inside I put a smoothed piece of PVC to not interrupt flow too much... I needed the 2.9L lid because of the stupid giant air muffler they put on the 2.3L lid that stuck out sideways basically to where the VAM is. This way I kept the stock ducting to suck from behind the grille, I haven't put a gauge to check restriction on the inlet side of the turbo to see if I'm losing anything but it meets my needs... Oh, that iteration is much cleaner than the metal clad drier ducting I used at first :), hey I was young and dumb and it was of course my daily driver...
Event Coverage
Featured Ranger Based Vehicle
