Floor pans
Featured Build Threads
glenny49
5+ Year Member
Ontario Canada
Hello again fellow members, I have another question about floor pans for a 1984 ranger regular cab. The original seat is a bench seat. I want to replace it with my bucket seats that came out of a Bronco. My question is the following, did ford manufacture the floor pans with the provision so a person can do this, in other words if I went to the trouble of removing the bench seat that is there now and rolled back the floor mat will I see 2 holes in the floor pan with say plugs that can be taken out to install bucket seat seat brackets? Let’s just say I’m lazy about doing the seat removal thing to look for myself.
I do not know about your particular model truck, but Ford never did this for any other vehicle they made. So I will venture a guess and say no, you will have no threaded holes for the center part of a bucket seat. They usually welded in re-enforcement in the floor pan along with welding in the mounting nuts.
That's the problem you run into, the floor is not really made to mount a bucket seat to it if it wasn't designed for it. People use large washers and get away with it though.
Don't used the same size washer above and below the floorpan. That will have a tendency to act like scissors with vibration. Also washers have a sharp edge. Keep that edge away from the pan.
Thanks franklin2. You’ve been quite helpful here. I’m going to go for it.
Not sure how I missed this for a week. My first truck was an 84 regular cab (RC) w/ bench seat, I've also got an 86 RC W/ bench, and an 85 RC that was factory buckets and center console (but swaped to bench by a PO). I can confirm what Franklin said, if your truck shipped with a bench seat, the holes for the inside bucket tracks weren't drilled and did not have the nuts and reenforcement plates added.
Having said that, the floor pans for the 83-88 RC (maybe 89-92 as well) were the same stamping, they just didn't do the extra steps to drill the holes and add the hardware. That means that the floor pan should be dimpled where the holes for the inner tracks would be located. Drill those out, then add reenforcementplate and a nut to the bottom side.
You will have an additional challenge for your stated goal. The front portion of the BII floor pan's shape (where the front seats mount forward) is shared with the extended cab Ranger. It is shaped different than the RC Ranger. The seat tracks will not interchange. Your best solution for using the BII buckets in your Ranger is to track down RC seat tracks from an 83-92 truck with buckets or the 60/40 split bench. The tracks will swap between those seats (even some newer), but not between cab types.
Event Coverage
Featured Ranger Based Vehicle
