'95 Supercab Rehab - Dumb Questions Thread
Most recent, comprehensive other thread about the problem, for reference. On the leads there, Redmond closed up, and I don't know anyone insane enough to pay Morana $900 when the going rate for an entire engine here is $650.
We'll find out tomorrow if filling it with weld and refinishing the bottom is good enough.
No dice. Looks like it leaks substantially less, but still enough to smoke. Figure it's just gonna bend wherever the new weak link is between weld and old tin, and not give me enough clamping force.
Not sure what consumption is, but you can smell the smoke in the cab when you're not moving, and 90% of this truck's purpose is to tow my boat in the summer, which is basically guaranteed bumper-to-bumper traffic.
I guess I can try to cut a spreader ring that hooks all the way around that corner to the next 2 bolt holes, or rebuild the entire flange like rhekman did. I have zero experience on the plasma cutter, though.
Do 2.8/2.9 covers fit the 4.0? Modifications needed? Apparently UK ebay is lousy with them, they just don't come up right away because they call valve covers "rocker covers". Lot of 'em look rusted to shit as well, though.
Without seeing it in person it would be hard to make a recommendation, you could probably put it on a flat surface and bend things so the bolts are above the surface and the middles are the low points and get somewhere...
If I get to salvage yards at some point I can keep an eye out for passenger valve covers... If I remember right they're kinda a pain with the coil pack in the way...
Well, feck
Since junkyards no longer exist here, and apparently you can't buy these anywhere? (even ebay only seems to have passenger's right now) this is less than optimal.
After thought, but it looks like the place where it seals against the head is nice and smooth. Would it be possible, after cleaning, to build it up the top side with JB weld, sand that flat and fabricate long skinny washer so you don’t crack the JB weld when you snug it down?
I’ve never done it, but once in a blue moon, I do something a little “shade tree”……
I'm honestly not sure exactly where it's still leaking from. I only saw a little bubble right below the bolt, so I yanked the bolt and reset it in rtv. It's gonna take another drive to burn off all the residual oil that was already on the exhaust, so I can get a better idea.
If anyone does come across one and wants to part with it, this is the driver's cover, not passenger. Not sure if you can spin a pass cover around and use it on the other side if you can fab the oil fill into a pcv instead.
Fair, the talk on what side it was on was on the previous page and wasn't invested enough last night :).
It might be a while before I head to a junkyard but I'll try to remember to put it on my perpetual junkyard parts to watch for list...
Well, feck
Exactly what year and what engine? I looked back in the thread, and I couldn’t find it. I think I have the valve covers from my 87 2.9 from the blown motor, but they may have been used on the rebuilt motor.
I’ll plan a trip to the salvage yard for several things, and you could find a lot of stuff down here that has no rust on it at all. Please just give me the specific year and engine, and I’ll see what I can find.
With every respect, also, don’t hold your breath, I’m not exactly sure when I can make it over, but I’m thinking in the next couple weeks
1995 4.0 (OHV). No sweat, and I appreciate it. I'll keep trolling ebay on my end as well.
With any luck the smoke will clear up a bit over time. Hopefully there's not a bigger leak off the back of the motor somewhere.
