'95 Supercab Rehab - Dumb Questions Thread
No dice. Looks like it leaks substantially less, but still enough to smoke. Figure it's just gonna bend wherever the new weak link is between weld and old tin, and not give me enough clamping force.
Not sure what consumption is, but you can smell the smoke in the cab when you're not moving, and 90% of this truck's purpose is to tow my boat in the summer, which is basically guaranteed bumper-to-bumper traffic.
I guess I can try to cut a spreader ring that hooks all the way around that corner to the next 2 bolt holes, or rebuild the entire flange like rhekman did. I have zero experience on the plasma cutter, though.
Do 2.8/2.9 covers fit the 4.0? Modifications needed? Apparently UK ebay is lousy with them, they just don't come up right away because they call valve covers "rocker covers". Lot of 'em look rusted to shit as well, though.
Without seeing it in person it would be hard to make a recommendation, you could probably put it on a flat surface and bend things so the bolts are above the surface and the middles are the low points and get somewhere...
If I get to salvage yards at some point I can keep an eye out for passenger valve covers... If I remember right they're kinda a pain with the coil pack in the way...
Well, feck
Since junkyards no longer exist here, and apparently you can't buy these anywhere? (even ebay only seems to have passenger's right now) this is less than optimal.
After thought, but it looks like the place where it seals against the head is nice and smooth. Would it be possible, after cleaning, to build it up the top side with JB weld, sand that flat and fabricate long skinny washer so you don’t crack the JB weld when you snug it down?
I’ve never done it, but once in a blue moon, I do something a little “shade tree”……
I'm honestly not sure exactly where it's still leaking from. I only saw a little bubble right below the bolt, so I yanked the bolt and reset it in rtv. It's gonna take another drive to burn off all the residual oil that was already on the exhaust, so I can get a better idea.
If anyone does come across one and wants to part with it, this is the driver's cover, not passenger. Not sure if you can spin a pass cover around and use it on the other side if you can fab the oil fill into a pcv instead.
Fair, the talk on what side it was on was on the previous page and wasn't invested enough last night :).
It might be a while before I head to a junkyard but I'll try to remember to put it on my perpetual junkyard parts to watch for list...
Well, feck
Exactly what year and what engine? I looked back in the thread, and I couldn’t find it. I think I have the valve covers from my 87 2.9 from the blown motor, but they may have been used on the rebuilt motor.
I’ll plan a trip to the salvage yard for several things, and you could find a lot of stuff down here that has no rust on it at all. Please just give me the specific year and engine, and I’ll see what I can find.
With every respect, also, don’t hold your breath, I’m not exactly sure when I can make it over, but I’m thinking in the next couple weeks
1995 4.0 (OHV). No sweat, and I appreciate it. I'll keep trolling ebay on my end as well.
With any luck the smoke will clear up a bit over time. Hopefully there's not a bigger leak off the back of the motor somewhere.
EDIT: Car-part shows a ton of yards willing to pull valve covers off the 2.3/3.0, not so much the 4.0. Called the first yard listed (multiple units) that does shipping, and they said what I saw were out-of-date listings from 2019!
Fortunately, after a few more days driving around after setting the bolt in rtv, the burning smell is only intermittent now. Good enough to keep driving it, at least.
FYI, my 94 Aerostar engine had spreaders on the valve cover bolts. I noticed after I swapped engine that the 94 Ranger engine should have. Without them the bolts bottom in the head at roughly the same time as they get snug. Mine loosened up about every other oil change. I should've just made it a habit to tighten them when I did oil changes.
Understood. I looked around in the shed of miracles, but I’m pretty sure we used the valve covers when we put the rebuilt engine in. That was a 2.9/1987. But I’ll take a look the next time I go out.
Swapped the rear axles. Stuck on the parking brake hookup on the '95.
I can pull the front cable (I think) all the way out, and I can use ratchet straps to tension the rear cables to the limit, and I'm still >1" short of connecting front and rear. It's not even close.
EDIT: Okay, the problem is I wasn't getting the actual attachment slack in the front cable. I feel pretty stupid, because I've always felt like Ranger parking brake cables were a gigantic pain in the ass, and this makes a night-and-day difference, but a lot of posts don't even talk about it.
The ones that do (and the manual) talk about "inserting a pin" into the pedal mechanism, but this is a really bad way to describe what you're actually trying to accomplish, which is prying down on the lever with the rotary spring on it.
Can anyone describe, or better yet share a pic, of how the bolts work below the center console bracket in an extended cab with factory buckets?
I have a junkyard console, but when I drill through the divots in my truck where it's supposed to mount, the front holes are almost directly on the vertical part of a structural rib, so I can't just run a bolt through without carving out more of the rib, or tacking in a stud or something.
I feel like pics might help here.
What console are you using?
This thing:
I don't know if originally the bolts go through at all. Might just be studs coming out of the floor. It looks like the front anchor wants to be a nutsert or a nut tacked to the bottom of a little rib inside the cab.
