93 Splash in SC, V8-Swap version
Plan A didn't work for the seat installation. I would have had bolt heads interfering with the slider rollers. I actually damaged the one slider and had to completely disassemble it to straighten out the roller cages. Got it fixed. Anyway, plan B involved a little bit of welding and the seat is about 3/4" higher than it would have been. I still ended up with more headroom than before. Passenger seat is in and it slides forward and back as it should.
OEM Brackets and sliders.
1" angle welded to the slider top pieces. I added some 1" tubing gussets for strength. I don't think havung the angle edge welded in place was strong enough. The seat mountung holes near the center console are centeted over the original slider. The holes on the door side needed to move out roughly 1 3/4". I could center it and might on the driver side. But I think I like the extra room next to the center console.
I don't think the thigh bolsters are quite as tight as I made them sound. It's more that I'm just not used to having them there. I sat in this for a few minutes after getting it installed and I think it's going to be fine.
Here you can see how it sits on the 1" angle
Welders fix everything and you're likely shrinking as you get older, so it should all work out.
Worked on the driver seat today. Had more prep work to do. I had a bunch of sloppy "Eric Wiring" wadded up under that seat. I straightened that stuff up. And while I had the seat out, I lifted the carpet and removed the wiring harness for the 1354E and its control box. Then vacuumed the carpet and UNDER the carpet. I'll remove as much of the remaining t-case wiring as possible (pushbuttons in dash and power supply?) When I tear into the engine swap. So, whoever buys the t-case can also have the control box and 97.5% of the OEM wiring harness to make it work. All my metal is cut and drilled. So, if I get enough non-rainy time tomorrow, I can weld the seat brackets in and finish the driver seat.
Should be a good window between tomorrow afternoon and Sunday evening.
It's been on and off all day. Got the seat done between raindrops. Then drove it to Rural King as a test ride.
Welding finished.
That's a busy ceiling you have...
Seats look good.
I removed the headliner. Then installed sound-mat and velcro loop material. So I can put patches up there. Also my auxilliary light switch panel, remote speaker for the GMRS radio and LED strips to replace the dome light. I'm pretty happy with it.
In the regular cab, that manages to seem taller in the cab and more modern at the same time.
Dang it, Ford!!!!!
So, rumor is that to fit my 4406 t-case under the Ranger, I will need to clock (rotate) it a few degrees because it won't fit between the frame rails. A while back, i saw a clocking ring on the internet. But it was expensive. Over $200 if I recall. I figured I should be able to design one and make it or have it made for a lot less. So, i took some quick measurements, designed a ring and added 2 extra sets of bolt holes at 10 degree intervals. I thought I could have a template 3d printed that I could then use to mate the t-case to the transmission tailhousing and figure out how far to clock the t-case so it would clear the frame rail.
Well, it turns out that the bolt holes are not evenly spaced around the housing. I made my template with a nice neat even 6-hole bolt pattern. And only one hole matches up.
Back to the drawing board.
My 3d printed template. 3 nice 6-hole patterns at 10degree intervals.
Here are the actual bolt spacing distances around the circle. You can see that most of the measurements are close to the same. I'd like to hurt someone.
You sure it won't fit as is? The 1356 is the one with the super offset front output that doesn't fit good, the 4406 is fairly short coupled, I would think you would be able to shift the transmission mount a little since you have to make all that up anyway... I know it clears the explorer frame fine but they flare way different than Ranger frames... then again I haven't started at that part in a while...
No. I'm not sure. I really started fooling with it seriously today. I need to crawl under the truck and take some measurements. I just got the t-case up on the bench where I could play with it comfortably today.
I just crawled under there and tried to get some measurements. It's at least an inch too wide. Maybe a tad more. There is a tab with a hole in it, probably used for lifting during assembly, that I could cut off easily and gain exactly 1 inch. See photo below. That would get it extremely close. It all depends on where the motor winds up sitting. I also discovered that my t-case tail shaft housing is going to be close to the front corner of the fuel tank. If that's an issue, it's close enough that a dead-blow hammer can solve the priblem at the expense of a few ounces of fuel capacity. My transmission mounting point will need to move forward an inch. All this is assuming that the rear of the engine block sits where the present one is.
Anyway. I'm going to hold off on making a clocking ring. I can easily assume that 10 degrees will be enough if I do need it. Any less than 10 degrees and I think adjacent holes will be too close together for good strength. So, I'll get the CAD drawings ready to send out "just in case".
5 minutes with a porta-band and a file right here will gain me 1" of needed clearance.
