2.9 running rich
chavo6723
Forum Member
Bosque Farms
NM - USA
Vehicle
Drive
Hey guys. I've rebuilt my 88 ranger 2.9 l from top to bottom. My engine is running rich. I've replaced the idle air control valve, the o2, sensor, the pressure regulator twice, New injectors, New coolant sensor, map sensor twice, the computer and I've also shot all the wires. I did fuel pressure leak down test and it stays solid. With the key on run it's at 38psi. While running it's constant 32psi. My oil is getting diluted with fuel. All the vaccum lines are new. I'm running out of ideas here. Any help would be appreciated.
@chavo6723
What exact procedure did you follow to size and index your RiNGS?
You tried pulling codes?
I'm not getting any codes at all. I'm thinking it is the eec relay that's at fault. I retired everything that has to do with emissions and put in a new eec with no luck. Having problems finding a relay though.
I gapped the rings to spec and I indexed the rings properly as well.
The relay is just a standard 12v relay.
However if that was bad it wouldnt even run
What did you mean by “I retired everything that has to do with emissions”?
Do you still have your original injectors? If so I would clean them, test that they hold pressure when not charged and swap them in. It sounds like the new ones are dumping too much fuel. We can’t see the fuel trim with EEC4, correct?
Sorry. I re wired all the emissions components. I do not have the old injectors anymore. I did not go cheap on injectors I went with accel from summit. I hope that isn't the issue.
