DRanger024
Permanent Noob
⭐Supporting Member
💻 TRS Socials
Ham Radio Operator
- Aug 16, 2007
- Dale
- State - Country
- WI - USA
- Other
- 2016 Lincol Navigator
- Vehicle
- Ford Ranger
- 4.0 V6
- Manual
Got tired of the creaking QA1 Rock Ends so I finally ordered replacements. Decided on Trail Gear Creeper Joints and from the best I can tell, there isn’t much difference between them and Johnny Joints but there’s a huge difference between them and the Rock Ends.
That’s a 1.25-12 creeper joint. In front of a 4.0 OHV throttle body.
Pros: fully rebuildable, greasable, come with the jam nut, fast shipping through Summit Racing.
Cons: They’re wide.
So I put them in
Measured from the ID of the bushing bore to the face of the insert. I measured the bore of both when I took the initial measurement. I had to subtract 0.030” from that length to set the new joints.
These joints made a world of difference in how quiet and solid the truck feels going down the road. I do not regret that purchase one bit. Only complaint I have is how wide they are. Not a lot of room for movement with the body of the joint being so close to the width of the center.
Seems to be plenty of room for the suspension to cycle though. I haven’t noticed any witness marks in the brackets and I flexed it as hard as I could. There’s enough room in my bracket to where I could shove a hardened washer inside on both sides of the joint if necessary.
Cons: They’re wide.
So I put them in
