steelhorse9859
- Feb 12, 2017
- Reaction score
- 0
- Location
- Tempe, AZ
- Make / Model
- Ford
- Engine Size
- 2.9L V6
- Manual
Hello,
This is my first post and am really looking to get some help I apologize if this isn't the right place.
I have been having an issue getting my 88 Bronco ii 5 Speed Manual to idle where it is supposed to. What happens is that when the engine is cold started the engine RPM will sit at about 1100 RPM for a few moments then it will slowly drop lower and lower. When the idle RPM levels out it stumbles around 500-600 and sometimes at startup it will stall out and die with the idle drop. The engine is supposed to sit right around 850 at idle as the 5 speed if it was an automatic it would be around 800. I am about to start pulling my hair out trying to figure out what to do to get this under control. I am able to drive the truck around and when it is in gear and moving their doesn't seem to be a complete loss of power. If I pump the brakes the idle will rise to where it is supposed to be, but once I stop doing so it will drop down to 750 and settle around 500-550. I am willing to post a video of what it is doing and link it if need be.
I want to include all the things that have been replaced so far in the truck. Now before I bought the truck (which was Jan 1, 2017) both fuel pumps (inline and external) and filler neck was replaced. I am not sure about the fuel filter.
Trying to figure out my issue and having a couple other ones I have replaced the following since Jan 1 2017.
New Spark Plugs (all where gaped to specs found in the service manual
New Plug Wires
New Ignition Coil
New Thermostat (190degree F)
New MAP Sensor
New Throttle Position Sensor
New Idle Air Control Valve (IAC Valve) - The most common thing I see to replace on the forums
New Coolant Temperature Sensor
New Air Charge Sensor
New PCV Valve
New Power Brake Booster
I also removed the oil sender unit and installed a mechanical gauge to monitor oil pressure instead of having a low oil pressure light which would only illuminate once the oil pressure falls below 5psi.
Any help here is so appreciated! I have double and triple checked the IAC valve and do not believe that my replacement is faulty.
P.S. There is no EGR valve on this model. If there is it is really hidden somewhere that might not make sense.
Thank you!
New Plug Wires
New Ignition Coil
New MAP Sensor
New PCV Valve
Thank you!
