lil_Blue_Ford
6,192
Butler, PA, USSA
4.9L
I'm in the same situation. I've shoe horned as much as I can and still get vehicles in the garage.
I’m shoe horned waaay beyond that point right now…
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
My truck had sat for about three weeks. Went to start it and the battery was dead. Grab my battery charger... I couldn't get it to work. So I grabbed my jump pack... no go. Tried to charge the jump pack... won't even take a charge. So I ended up with a new battery charger. I bought a Schmacher. It's way more digital then I wanted but most of them are these days it appears. It did work well... set it at boost and the truck cranked right up. I then stuck it on the Bronco II and have that battery a full charge.
Uncle Gump
Token Old Guy
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
After burning up my cheap M12 brushed drill... I started looking to replace it. I'm pretty committed to the M12 stuff for my travel tools at this point. So I found a deal on a M12 1/2 chuck hammer drill. $67 with no battery. This one will work circles around my cheap brushed drill... and not that I will use the hammer function that often... it will be nice and I don't have to take my Dewalt hammer drill all the time.
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
When I bought my M18 drill I really wanted the fuel version, but I didn't want the hammer drill feature. For what I was planning on using it for it would have just been added weight. Luckily they did offer a brushless non fuel M18 drill, not nearly as powerful as the Fuel version, but I settled. Still better then my old brushed Porter cable drill, and even a couple corded drills.
Uncle Gump
Token Old Guy
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yeah... this hammer drill is heavier.
But I'm done with the non fuel stuff. I'll spend a few more dollars.
mikkelstuff
469
Brighton, CO
3.0L
Just bought a JOMON JM-218 rivet gun adapter off Amazon. I need to install about a hundred pop rivets in my latest home project and I'm told these work great with a cordless hand drill. I was rather dreading that pop rivet installation with a plier type hand tool.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
Got a 7 piece set of Husky Swivel head Ratchet wrenches with my Hope Depot Cristmas card.
Also got 2 sets of small plastic shelves to help me get organized.
With the few bucks I got left on the GC, I'm going to get lawn mower stuff for the upcoming spring, It's like 4 weeks away.
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
I have a favorite brand of knife, it's the "Studies and Observation Group" often referred to as SOG. I was using a a full sized SOG SALUTE mid-lock, which very much surprised me for both edge retention and toughness. I hated how it opened but gave it a try. As a work knife, it is quite a SOLID value listing under $35 from the PX.
I had been reading good reviews on their TERMINUS XR and XR LTE models, making use of their new XR locking mechanism. After modest deliberation, I chose the improved and higher rated LTE. Since it would always be on.me, I chose the Ti finished blade with Carbon Fiber scales for it's light weight.
It operates great, ESPECIALLY THE LOCK! It is very easy to flip open (3 different methods to deploy the blade) is super duper light but is only OK for a pocket knife; a bit on the fancy side and it's super light. The 3" blade isn't up to many of my daily chores.
My next knife prospect was a SOG FLASH AT; it uses the same locking mechanism as the Terminus but instead of flipping to open, it uses a spring assist mechanism.
The Flash AT is no lightweight measuring 5.2ozs, it rides deep in a pocket and when deployed it is audible and apparent that a blade has been introduced to the situation. When this thing opens, nearly anything in the way will be moved out of the way; it deploys with authority and force. It is up more than any daily chore use, sharpens well and holds a great edge. The handle is appreciably larger than the blade, I really like how it feels. It provides even better control of it's thick bellied blade.
Though I will concede that the technology built into today's flippers negates the need for an assisted open knife, this Flash AT was money well spent as a work knife. I have adopted it as my every day carry (EDC) knife. Consideration should be lent to state and local laws regarding blade length. In my pocket this knife is considered concealed and it's blade is tap dancing near 4". I maintain a CCP which covers me carrying in this manner, though otherwise it would be an issue in Washington.
If you have a CCP or are permited by your local laws, I highly recommend the SOG Flash AT, it is a great value, very stout and I believe it will experience a long happy life of abuse. If you are interested visit their website as I bought it direct from them; the primary reason being they have GREAT daily specials. I was able to grab the Flash AT for less than half their MSRP with free shipping and a DISCOUNT code during the Black Friday promotion.
Elutheros
129
Central Texas
Not so much bought as built: 2" x 72" belt grinder. Besides making knives it has a lot of other uses.
Uncle Gump
Token Old Guy
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I have often wondered but haven't seen or found one. If there is would someone please move this post?
A Harbor Freight Tools opened nearby recently and I got an Inch-Pound Torque Wrench, but was not able to view one outside a sealed box.
After getting home and looking it over I discovered it had only a 1/4" drive head, which was already seeming too loose.
My next trip by there I took it back but am still at a loss as to finding one that's affordable and doesn't require paying shipping.
Any ideas of a good way to go?
Just moved this post as PO suggested.
lil_Blue_Ford
6,192
Butler, PA, USSA
4.9L
@Josh B
I got one of the 1/4” HF inch/lb torque wrenches. The head only wobbles when you back off the tension, or rather should only. Honestly, it is kinda cheap but it seems to work ok. Best way to keep torque wrenches accurate is to always back off the tension when it’s not being used. I bought a 3/8” inch/lb beam style from a traveling tool sale back when that was a thing, but I like the click style better. I also have a Craftsman 1/2” foot/lb one that seems pretty decent for a not overly expensive one. Lowes had the Craftsman ones on sale back during the holidays, I was kicking around buying a 3/8” click style. Also, Autozone has some that look decent, believe they are OEM brand.
Uncle Gump
Token Old Guy
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Clicker torque wrenches have their place... but so do beam wrenches. I have both in 3/8 and 1/2 inch. Only a beam style inch pound. Hard to use a clicker to check pinion bearing preload.
oldgeek
1,027
USA
Ranger XLT
I got to borrow an old Starrett dial inch pound torque wrench for the pinion gear on the rear. That was real handy as it quickly shows you what force it takes to turn the pinion.
