Installing AC in a non AC 1st gen ranger? Have a 302/c4 swap
09Stang
Blackshear
302
3in
Hi everyone, I thought I may post on here since I can't find any real in depth knowledge on this subject.
My dad and I built an 83 ranger into a race truck. It's got a stock 302 from blueprint, a non AC CVF serpentine kit (with power steering). It has a street built C4 auto from TCI.
My dad and I have been wanting to do an air conditioning swap in it with as little headache as possible. Truck has no radio from the factory or ac from the factory. Any tips or knowledge on how to install this would be great! Any cooling upgrades needed as well would also be appreciated if required
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I used a Vintage Air heat, a/c, defrost system on my 93 because it had no heater box at all. It cools and heats OK but the defroster isn't great because it uses only recirculated air. If you have a factory heater box, I'd get one of their kits with the evaporator that hangs under the dash like a 60's Mustang. That way you'll still have an effective defroster and the installation will be easier. I used fox Mustang front drive brackets and pulleys with the Ford Performance 351 front bracket but I found out afterwards that Vintage has a decent looking compressor bracket, too.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
svtcards
137
Lyman maine
302
3'' front 4''back
I used a Vintage Air heat, a/c, defrost system on my 93 because it had no heater box at all. It cools and heats OK but the defroster isn't great because it uses only recirculated air. If you have a factory heater box, I'd get one of their kits with the evaporator that hangs under the dash like a 60's Mustang. That way you'll still have an effective defroster and the installation will be easier. I used fox Mustang front drive brackets and pulleys with the Ford Performance 351 front bracket but I found out afterwards that Vintage has a decent looking compressor bracket, too.View attachment 78229View attachment 78230
What did u use for a fan and radiator?And did u make that shroud for it?
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Bird did this on his first gen... not saying you want to do it exactly this way but the thread has lots of useful info.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I used a belt driven 15" Derale flex fan, a Griffin universal radiator that I mounted inside the core support after I cut it for clearance. I built the shroud from a Summit Racing kit. Idling in traffic with the a/c on at 90 degrees, the temp gauge will go up about to the middle.
09Stang
Blackshear
302
3in
So vintage air can supply the hanging evaporator? My heater box and core is great with heating. And can I put in the evaporator without removing the dash? Also what can be done to modify the cooling if necessary? I have an L&L products radiator with a big low profile electric fan w/o a shroud. Stock drivers side water pump as well
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
You should look at their website, they offer lots of choices, the underdash unit looks like this:
09Stang
Blackshear
302
3in
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
You're welcome. My a/c quit and I found that the front seal on my Napa reman compressor is leaking- after 2 years and about 5000 miles so I'm stripping down the compressor I got with the brackets, planning to reseal it and install it. I figure I'm better off rebuilding a Ford part than trusting another dubious reman.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Good idea. I had been replacing compressors about once a year because the only thing I could find was cheapos from autozone. Finally got a decent one online and it seems to be holding up.
