I has an issue!!!!
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
So, I finally get back from my company trip and I go to start up my truck. And she happily started right up after sitting in the work parking lot covered in snow for 3 days.
I let the engine warm up and the idle dropped, which it has been doing this for a few weeks now. First thought it was the cat, checked that.. it seemed fine. Then decided it was the EGR, tested that and it's fine, although I still need to take the manifold off and clean that passage way.
But I went and filled her up with gas and decided to take the longer highway road home so she can run for a little bit. After slowly getting up to 4th gear (with the low idle)... then finally up to 5th gear but the idle didn't want to get high enough to run good in 5th, dropped it back down to 4th (after cussing at the %$#^#$% behind me comin up on my @$$. I have the worst road rage.) then I noticed.... semi-large (roughly about 1-3inch long) RED HOT EMBERS comin out of my tailpipe!!!! only one or two pieces came out, I saw them disapear in my rear view, so I took the next exit and went straight home.
WHAT THE HELL IS CAUSING THAT CRAP TO HAPPEN!!!!!!:shok:
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Over fueling causing the catalyst to melt down and fall apart.
kimcrwbr1
46
maplevalley WA
2.8l
How did you check the cat/muffeler. With the engine running put your hand over the tailpipe and have someone rev up the engine. If the pressure coming out dont increase with rpm you have a restriction in the exhaust system. Before you put in a cat you need to determine if the engine is burning oil (valve guides or rings) any oil getting into the cat will cook it real fast.
straycat
77
02 06 and 2012
Jeeps
Well, the engine is getting more fuel than your ingnition system can light causing raw fuel to be dumped into the exhaust. I would suggest you have a mechanic check for fuel injectors staying open, if that is not the problem have an analysis done on your ignition system to check primarily your spark. If you cannot do this yourself....please....make sure you get your vehicle checked as soon as possible, this is extremly dangerous.
Be safe and stop that road rage...it will just cause you to get ulsers....lool
straycat
77
02 06 and 2012
Jeeps
That would be over-heated chunks of catalytic converter blowing out the tail pipe.
Take the cat out and check it out. If you can see from either end that it is visibly melted down (meaning that it is destroyed anyway) punch it out, put the shell back in and run it up the road. If it is better get your fuel delivery issues figured out and fixed, then get a new converter in there.
If it isn't melted down, put it back in and take the muffler off, run it with no muffler or tail pipe and see how she is.
Also, I have to address your use the word "idle" (and get my head taken off I'm sure).
"Idle" is the term that refers to the engine running the the trans in neutral and no throttle input from the driver. I count several places where you use "idle" but the context indicates that you were trying to drive, and thus the engine was not "idling".
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Engines can idle in gear or park as well.
Richard
Richard
My grammar points were related primary to her truck. She has a stick. Show me a manual transmission (I will not accept the Saab that had a sprag clutch) idle in gear and I will concede the point for this case.
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
As relating to specific truck....OK
Richard
17,929
SW Iowa
Case-O-Matic
Manually controled torque converter in front of a 8/2 speed manual geardrive transmission.
Moot I know because it is completley different than a M5OD.
I am going to guess "idle" meant it couldn't raise the RPM... like it always seemed to be trying to idle, which is consistant with a really plugged exhaust.
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
Cat: Lima looked under my truck and shook the cat and nothing rattled in it. so we moved on to the next thing.
Fuel: I always fill my tank up all the way (and hardly ever let it get bellow a quarter tank) I put 11 gallons in last night on top of the quarter tank that was in there already.
Idle: I didn't know. I was under the understanding that Idle was rpm, obviously my lingo is all backwards (I have a habbit of using the wrong vocabulary, my mom blames it and my horrible spelling on phonix.)
My Idle dropps while running in nutral when the engine gets hot, the RPMs stay low while in gear. happy?
Have not looked under or got in nor started truck today. Been two busy with errands with my stepdad (we coach Alaska native games at a middle school and had to lots of stupid paper work.)
I will text Lima and try to get over to his shop after both my jobs tomorrow and run though the things you guys suggested.
I'll update after. thanx.
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
Oh, yea...Palin carries....Rabies!!! lol
:icon_rofl::icon_rofl:
Btw... palin is a ****ing DUMB @$$ RETARD!! She's not even a real alaskan! her tv show is a #$%^#$% JOKE! people don't do that #$%# in Alaska, not unles you have your own plane or you're a rich MOFO!
I would like to pass a law were Palin is not allowed in Ak anymore! lol
17,929
SW Iowa
When the cat is fed a constant diet of too much fuel, the ceramic guts get hot and collapse, filling in the holes the exhaust normally goes through. The engine is forcing air through the thing, you must have had some extra hot stuff around one of the holes the engine was able to keep open and blow it out the exhaust.
It was on tv so it has to be real :D
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
over fuelling relates not to how much gas you actually put in the tank, but how much is being dumped into the cylinder by the FI system...maybe you have too much fuel pressure...like high blood pressure...only your fuel lines are steel and they don't quite pop as easily as a blood vessel...
you are either not getting good spark at the cylinder or there is too much fuel...
