EGR connection with aftermarket cone filter?
Dprocks100
Salt Lake Utah
2.3
K I've searched this for weeks, and I can't find my answer. I have a 2.3L 1991 2wd and I have put on a aftermarket cone air filter. I currently don't have my EGR connected, and I passed emissions (live in Utah) and it doesn't throw a CEL. In my reading of the EGR, I have decided that I want it hooked back up. I don't really see a difference with it on or off, but I do with the filter and want to keep that on my truck. Anyways, Here is my question.
How have you guys connected it to the intake with a cone filter attached? or anything other than the stock air box? Has it been done? The tech library doesn't have anything about how to do it, and I can't find a thread about it. All the other threads are about whether or not to keep it on or off, or if its important, and thats not helpful to me.
Thanks!
Yeah, the EGR has nothing to do with the air box and vice versa. That should not figure into this at all.
Pics perhaps?
Dprocks100
Salt Lake Utah
2.3
Ok so this is what im talking about and what I believe to be my EGR. I could be totally wrong in thinking its my EGR but there is a flexy pipe that goes from my exhaust to this valve thing and vacume lines as well. Its before the stock air box. uploadfromtaptalk1396052175536.jpg
Sent from my HTC One using Tapatalk
Dprocks100
Salt Lake Utah
2.3
This is the flexy pipe in the engine compartment from my exhaust. uploadfromtaptalk1396052355144.jpg
That's not EGR.
That is the intake heater. It is used to get the engine up to temp quicker in cold conditions.
Dprocks100
Salt Lake Utah
2.3
So im fine without it? Other than cold starts, it doesnt effect my engine? Is the real EGR in the same place as RonD was saying on the 96? Thanks for your help!
You live in Utah? It's worthless.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
The EGR on a 96 is actually on the upper throttle body and you should see a pipe connection from the lower exhaust manifold that comes up somewhat behind the engine or at the back of the passenger side and connects near the top of the intake. It is at the back end of the engine with a wire connector somewhere near the top or side of it.
If you passed emissions you probably don't have to worry about it at all unless you start getting a CEL with codes indicating it is not working...
