Driver side door rattles excessively 1992 XLT
sauceman
15
Ford Ranger XLT
Hey Guys. The driver side door on my 1992 ford ranger has started to rattle quite a bit. It's as if it is not latched tightly anymore. What do you recommend I do to fix this?
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
Open the door and stick something in the latch to push it into the closed position so you can see if the latch is worn. My 162,000 mile 93 does the same thing and I'm going to check it as soon as I get everyone else's car fixed.
Elutheros
129
Central Texas
Loosen the torx bolts on the body side of the latch and tap it towards the passenger side slightly. re-tighten bolts and test to see if it pulls the door in tighter. The weather stripping is probably compressed and allowing the door to rattle. Adjusting the striker/lock plate fixed that on mine.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If none of those fix anything, look at the window guid in the door. I had one that was broken loose in the door of my previous Ranger.
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I found the plastic bushing on the latch stud missing on mine. The latch had actually cut far enough into the stud that I was expecting it to break off when i tried to remove it.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
My 87 does this and it cause the head is broke off the bottom mirror stud, allowing thr mirror to rattle around, Only applicable if you have the low mount swingaways
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
This happened to me on my 92 Explorer. I picked up a new bolt from the "HELP" section at your local auto part store and it cured my issue.
Could it be that something is rattling internally in the door, or is the entire door rattling as if it is not latching tight. If it is the entire door, then the striker bolt bushing is probably your issue.
Cory's2000XLT
Diana,Texas
Ford Ranger XLT
I have rattling in both doors. I've used an impact torque tool. The type you put a socket on the end. Put in / on the bolt/screw and hit with a hammer. Bent the teeth on the T40 TORX socket. It was a snap on socket. They didn't budge. I'm scared to drill out and tap the threads. Because if something goes wrong, I may not be able to repair it. Any suggestions??
sauceman
15
Ford Ranger XLT
Did you try loosening it with a vice gr
I know this may sound silly, but have you tried loosening it with a vice grip? The only other thing I could think of is maybe a higher quality TORX socket. Once you are able to get the bolt out, you will have to replace the "striker bushing", which is the little plastic piece that goes around the metal door latch. In my photos I have attached, mine are cracked, which is why my door was rattling so much. Replacing them fixed the problem immediately. Make sure when you take the metal latch off, that you properly align it when you put it back, typically there will be a ring from the dust that has accumulated underneath. I hope this helps.
Elutheros
129
Central Texas
I used clear tubing for the "bushing" and it works fine.If you can't remove the torx you can just slit the tubing and force it over the post.
Cory's2000XLT
Diana,Texas
Ford Ranger XLT
Mine is not the bolt style striker. Mine is about a 1/4" thick round piece in the shape of a 90° bend
Fast Eddie
2,656
On The Road
Ranger Edge
2x4 on 4x4 Factory Chassis
Post a pic of your striker and latch if you've removed the door panels and checked the internals.
look for movement marks on both the striker and latch. Had the same problem on my `04. Striker lost position and just needed to be moved inboard a little, not too much or you'll wear the latch and lose future adjustments. Happened to me right after my daughter slammed the door shut. Latch stayed but striker forced inboard. Let us know how you make out.
helpme
18
Hotlanta
My 94 is like your's Cory. I noticed that sometimes it closes well and sometimes it doesn't. I think its the upper door hinge that is worn. If you pick up on the rear of the door you can feel some slop.
