84 ranger headlight issue
chayse brooks
I have a 1984 ranger when I turn the lights on I have to use my high beams or the lights will not work. After a while of the lights being on the lo beams can work to but they only turn on about 15 minutes after the headlights are turned on. I thought it was the hi lo beam switch causing this but I'm not to sure anyone else having this issue
Have you tried replacing the bulbs?
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
there is a circuit breaker built into the main headlamp switch which gets twitchy with age,
ant particularly if the hi/lo contacts inside the multifunction (dimmer) switch have become worn.
I recommend replacing BOTH switches
I've personally repaired dash wiring damaged wiring (and near fires) caused by both switches
AD
