4x4 manual hub problem!! HELP!!!
zrange97
cincinnati, oh
so i went to the river by my house to go fishing and i engaged my manual hubs at the gas station down the road. i got in and started to drive off, i had no turning it just jerked the wheel back and forth when i tried turning. so i got out dis engaged the hubs and didn't go fishing :bawling:
The next day i jack the front of the truck up, took the wheels off and messed around with the hubs locking and unlocking. the passenger side works fine, but the driver side does not engage!
Also when i turn sharp after that night when engaging the hubs i get a grind :icon_confused:
Do i need new hubs?
or is my problem something else?
thanks for looking hope you can help me :icon_cheers:
snoman6115
Weston, WI
v6 4.0
well your wheel bearing could be on its way out. or your hub could either be rusted up and jsut stuck, and now a piece of rust is stuck in your wheel bearing. hard to tell without taking the hub off and inspecting it
Hanzo Steel
Aurora, Co./SFV Ca.
Have you taken them out and inspected them? What side is the grinding coming from, have you tried swapping the hubs.
Big Jim M
30
Austin
Sounds to me like you were on hard ground and the 4x4 was working as designed! Ya can't turn sharply on a hard surface in 4x4 without all the humping and jumping! Try it again on soft WET ground.
Big JIm
zrange97
cincinnati, oh
i have taken the hubs off and looked at them! my truck just got an alignment and wheel hubs/bearings were put in about 4 months ago.
its was not in 4 wheel, i just had the hubs locked in 4 wheel. the switch inside was still in 2wd
the only thing i have not done yet is flip the hubs.
Big Jim M
30
Austin
I think
I'd put her up on 4 jackstands and start her up.. That'll show you what you've got.
Big JIm:hottubfun::wub:
zrange97
cincinnati, oh
ok ill try that in a day or so and get back to you thanks
scotts90ranger
4,442
Dayton Oregon
2.3 Turbo
sounds like you have a locked up outer U joint. put the front on jack stands with it in 2wd and the tires on, cank the wheel so the tires are turned near lock. Lock one hub in at a time and turn the tire with the locked in hub, if it jerks around it's probably a screwed U joint but that's how you'll tell...
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
sounds like you have a locked up outer u joint. Put the front on jack stands with it in 2wd and the tires on, cank the wheel so the tires are turned near lock. Lock one hub in at a time and turn the tire with the locked in hub, if it jerks around it's probably a screwed u joint but that's how you'll tell...
+1
ad
zrange97
cincinnati, oh
check my other thread i updated it.
its under strangest 4wd ever!!!
tell me what you think
bigblockford79
West Michigan
466
Please make more threads on the same issue. Thanks
zrange97
cincinnati, oh
ok so i jacked the truck up on jack stands and turned the wheel to the left then engaged each hub separately!
The passenger side engaged and spun around thru the differential and up to the transfer case.
the driver side engaged and didn't spin at all, so i put the wheel straight ahead and engaged them again separately, again the passenger side was fine spun and everything, but the driver side spun like it was winding up and when it got to a certin point it turned the front wheels then eventually stopped/ locked up..???
Is it U-Joints??
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
You should be able to see it binding up. Like was mentioned earlier, look at the U-joint closest to the wheel (10-12 inches behind it approx). When you rotate it and get into the bad spot and it will try and rotate the "kink" (for lack of a better term) instead of rotating somewhat smoothly like a U-joint usually does.
zrange97
cincinnati, oh
it was U joints thanks i got them fixed and 4wd works :] thanks guys for all ur help
