Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Maybe its just jammed but my window motor stopped working all together, for me its less hassle just to swap it outThe window motors are really easy to fix they're harder to take out and put in then they are to fix. (Drill out the rivets)
there's video on YouTube how to do it.
They use the same mechanical principle that the shifter motor motor uses, a worm gear and a driven gear,
they are year and generation specific make sure you double check what generation your truck is
It seems it will load some pictures and others wont, I do not understandI have my shift motor taken apart, unfortunatly I can no longer post pictures on this forum, this started the other night out of the blue, when I hit the load button it just tell me upload failed?
I need to be able to post pictures here, I can post them on every other forum I participate in? Maybe someone can help with this?
I am not good at comp, I use mozilla forefox and Im not sure what operating system, thats about all I do/dont know.
Let me try it this way, I hope this works!Did you find the problem with shift motor?
Not sure why you would need to post pictures, loads of pictures of shift motors assembled and disassembled already out there, just reference those if there is a question
There is a limit to the size of the picture, for good reason, lol, resize images and see if that helps, i.e. your image above is 37.23 KB, and is a good size for posting
