4WD not working, please help me to get this fixed
1930
Brandon/Ocala Florida
Hi
At this point both four-wheel-drive lights are flashing on the dashboard again as I'm driving it.
4 High and 4 Low turning the knob on the dash does absolutely nothing to affect the motor that's disconnected from the transfer case and that I have zip tied to this Shield
I would think that I would or should test that the motor is getting power or something like that before I assume the motor is bad.
I doubt the motor has been even rarely used
1930
Got to be a way to test the motor by giving power to it I just am unsure how to do these things
Denisefwd93
74
South East PA
Please re read post #4
1930
I read that post many times, thanks. So I need to look at schematic again, determine the wire colors leaving the fuse panel, check for continuity of these wires down to whatever the next device will be.
I'm assuming (don't have schematic in front of me ) that the wires will run down to the relay.
I need to see that relays open and close as they should and then continue to follow schematic checking for power.
1930
I'll look at it better tonight and see what I can see
8,369
If you have a Volt meter set it for DC volts
Unplug the shift motor connector and connect volt meter's 2 probes, one to the Yellow wire and one to Orange wire
Those are the 12v/Ground wires that power the motor
Key on
Change 4WD switch setting and see if volt meter shows +12v or -12v that means GEM is activating 4x4 Module and its relay is working, but shift motor is not
If you don't get +12v or -12v then 4x4 module is likely problem
The +12v or -12v will only be for a second or two, and it might come up +12 and then quickly change to -12, or visa versa.
The GEM expects instant feedback from the contacts inside the shift motor housing when it activates the relay, since the shift motor is not moving the contact wheel, the GEM stops sending voltage and sometimes reverses polarity to move motor back to its 'original position', because if contact wheel was the problem and motor was working then the driver repeatedly changing the knob would get 1 or 2 seconds of power at the motor and the transfer case rod would move, and could end up in between "gears" or even in Neutral.
So start at the motor end and see if wiring there is getting +12v or -12v on the yellow and orange wires
1930
Key on
Very clear direction. Exactly what I was looking for
1930
I have a pretty good V.M at my shop. (Which I'm not familiar with using ) I'll drive out there and get it. Will post results tonight.
Thanks again
8,369
4x4 relay module is in the dash, it has the 2 relays inside it
The GEM module is behind the Radio, 4x4 relay module may be there as well, but could also be behind glove box, not sure in 1996
GEM module is working, i.e. flashing 4wd lights
Do you hear relay "CLICKS" when you change the knob positions?
If so relay box is working
If you tap on the motor part of the shift motor assembly you can sometimes break loose a stuck brush, this will get motor working again, but it is temporary, needs to be rebuild or replaced
1930
When I turn the knob I hear absolutely nothing
1930
So does the truck have to be moving running and driving for anything to happen because up until now I didn't think anything was happening but I'm driving along now and I switched it from 2 wheel drive to 4 wheel drive high and I heard the relays click in the 4 wheel drive light Dash came on
8,369
Then you most likely will need to pull off the center console cover and pull out the radio.
Best guess is the 4x4 relay module is in that area
GEM will be on the left side, lots of wires and larger module
4x4 relay module is probably on the right, much smaller, maybe 3" square, and just a few wires, look for wiring colors on the diagram
1930
C post above
1930
Things seem eratic, I've never heard anything up to now when I turned knob
