302 header problem
greenstranger89
hi im getting toward the end of my swap and im having major issues finding headers that work i got a set of headmans that were supposed to be for this swap but they didnt clear the steering shaft or the passenger side frame rail then i tried a set of explorer manifolds which cleared everything but the spark plug wires and boots because the plugs are on a different angle than an explorer so does anyone know if they make either a set of shorties or long tubes that will work and clear all the problem areas thanks jim....:icon_confused:
Psychopete
29
FW, IN
what are your header model #s? 89500? There's a header thread in the V8 section that has some decent pictures of fitment/different options. Tri-ys if you don't have the 164 tooth bell (like an AOD) would be a good option for 2wd (are you 4wd???). What engine mounts did you use?
greenstranger89
its an 84 motor out of a mustang into a 2wd 89 xlt ranger t5 tranny with the convertible mounts and advanced adapters motor plates and yes they are the 89500
Psychopete
29
FW, IN
The 89500s should fit, I used aa plates with those headers also. But I used Bronco 302 mounts and not the convertible mounts. It was a tight fit, but it did fit. Redoing mine, going with t-5 and tri-ys - would be worth while looking into. Will see if I can't find a pic of the driver's side Hedman header when I get back from the grocery store, g/f is looking at me ready to go now lol.
Psychopete
29
FW, IN
Only pic I can find. Pic was during the swap (was "done" and driveable) but due to body rust, just tore the whole truck apart - motor is going in a cleaner white '87, wish I could get a better pic for you.
superdave1984
24
KY
Sorry to jack the thread, but what radiator and hoses are you using?
Psychopete
29
FW, IN
It's a 2-row explorer radiator. I cut out the bottom of the core support and trimmed up. The top hose part number is 61037. Bottom hose is half '93 Mustang (top to fit the water pump) spliced into an LTD hose. Can't remember what year LTD, but I am going to do something different there. Hard because the lower hose outlet angles down. Piece of angle iron worked out ok as a base between the frame rails:
