tinman_72
- Apr 14, 2008
- 136
- North Georgia
- Ford
- Engine Type
- 2.5 (4 Cylinder)
- Engine Size
- 2.5
- 2WD / 4WD
- 2WD
- Total Lift
- Factory
- Total Drop
- None
- Tire Size
- 255/60R15
- My credo
- RoHS compliant
Hello fellow Ranger enthusiasts.
I have a '93 Ranger 2.3L that I am replacing the engine in. I lucked out and found a local '98 2.5L with 140K miles that I picked up for $300. I removed the head and had it rebuilt. The cylinders all look brand new with factory crosshatching and absolutely zero ridge at the top. (When I pulled the head off the 2.3L at 230K it also still had crosshatching and minimal ridge.)
I planned to put a new oil pump in as well since I am in there anyway. That is when I learned that it is $267 for a quality name branded 2.5L oil pump. That seems a bit insane to me. Can I put the auxiliary shaft from the 2.3L and use an old style pump (a new one of course) in this newer motor? $58 for a new pump seems much more reasonable to me and the one in my 2.3L has lasted 335K miles.
