2.3 oil pump in 2.5
4b316
4
Impressed,very nice the way you did it,my new route to go.I guess the only thing i would do,is get the 2.5 intake to work as they flow better but hey,if it runs fine.....
tinman_72
96
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Thanks for the compliments.
Unless you are doing some major porting work and can reprogram the computer to eliminate the EGR I highly recommend that you stick with the '93 intake. I could feel virtually no difference in power between the two intakes.
I wish I had taken pictures of the heads side by side; the '93 head intake ports were larger around but the valve guides came down farther into the ports. The '98 heads have ports that are more open where the valve stems enter the ports.
