1985 2.8 Carb Adjustments
8thTon
--- Banned ---
806
Pennsylvania
IIRC you rotate the choke body to make the fast idle screw align with the V (#4). Hold the throttle open a bit so it does not get hung up on the stepped cam and rotate it into position where it aligns with the V. Then set the fast idle speed by turning screw #4. The #5 screw adjusts how far close the choke plate is, independent of the idle speed - this set how rich the choked mixture is.
ford4wd08
513
Alcoa, TN
2.8 V6
Just when I think this thing is working right, I have another issue.....
Now it will stall out on me (I assume because it is flooding) if I don't let it warm up for a while. Only way I can restart it is to crank it for a while and hold my foot into it. Eventually it will come back around and run. But this has happened twice in the middle of the road. I have to really rev it to get it to stay running. Then once it is warm, no issues the rest of the drive. It only seems to happen in the first 5 mins of running.
Also, last night trying to leave work I guess I flooded it and absolutely could not get it to start. It took me an hour of fooling with it to get the flood to clear and get it to run.
My thoughts are right now is that the choke isn't opening fast enough, or I have it set too tight. I don't have a choke index on this carb; I assume because the choke was never meant to be adjusted due to emissions. I'll try loosing it a little today and rotating it towards the front of the bronco.
This engine floods very very easily...... Some of this can be Operator Error, but the stalling to me sounds like the choke still isn't right.
Carb gods, please lend me your advice.... @RonD @Uncle Gump @19Walt93 @kimcrwbr1
Edit: also I hooked the thermostat on the choke back up to the original wiring. I had moved it to the alternator at one point, but this weekend I wired it back up original wiring. Choke has done the same thing both times with both wiring.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,536
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
We all said... you will have to experiment. You will find the right way... you have to solve the puzzle.
The choke could very well be to tight. You're on the right track... loosen it up. Maybe adjust the pull off to help add a bit more air... maybe turn the fast idle up a touch. Experiment!
ford4wd08
513
Alcoa, TN
2.8 V6
That is the sole reason I'm driving it to work everyday this week!
As long as I'm in the right mindset I'll experiment. It sucks stalling in the middle of the road!!
I'll open the choke up some. Man this can get frustrating!
Uncle Gump
Token Old Guy
13,536
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Take a deep breath...
If it does flood on start up... block the choke plate open.
ford4wd08
513
Alcoa, TN
2.8 V6
Deep breath taken..... LOL
Here is the issue, it will run fine in the driveway at idle, until it drops in gear (auto trans) on the road it will die until I have run it for a while.
I blocked the plate open yesterday and could not get it to start without laying starting fluid to it, but I must have really flooded it.....
19Walt93
4,492
Canaan,NH
351
3"
235/55R16
I wouldn't turn the cap leaner, I'd try changing the pull down adjustment first. It sounds like you need to set it with a little less pulldown. One of our salesmen years ago had a V8 Granada demo that would stall on takeoff cold, I set it to spec, rechecked it twice after he complained, and he still wasn't happy. I had him leave it at the shop one winter morning and start it with me in the car, it took right off and within 5 seconds he had it in drive at about 1/2 throttle and it stalled and was hard to restart. I ended up with the pull down at .090" to compensate for his driving habits.***If your Bronco has been flooded you should check the dipstick for a gas smell and probably change the oil.
Uncle Gump
Token Old Guy
13,536
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Great point Walt... One of the worst things with a choke is their ability to foul perfectly good oil when they act up or aren't right.
ford4wd08
513
Alcoa, TN
2.8 V6
Just to confirm, when you say pull down, you me the vacuum pull off?
Also, one thing I would like to make sure I understand, my vacuum pull off does not move until the engine is running. I've read that the starting turning the engine over would move it, but mine does not. It has to be running before it will actually pull off the choke.
Note taken on changing the oil. I'll do that soon.
ford4wd08
513
Alcoa, TN
2.8 V6
One more question..... When it is stalling after start up like you describe. I assume it is because it is flooding, right? From what you are telling me to do it sounds like I should make the pull off tighter than more open? Wouldn't that cause a richer condition? I think the pull off is .250" now.
8,372
Back in the day we used a wooden clothes pin on the choke plate so it couldn't close all the way :), a proper DIY fix, as long as it doesn't hit the air cleaner top it will allow choke plate to open all the way
19Walt93
4,492
Canaan,NH
351
3"
235/55R16
I think you'll find .25" is too much pull down. You're measuring at the top of the choke plate, right?
ford4wd08
513
Alcoa, TN
2.8 V6
Yes, I am. I also think I am having some binding in the linkage. I tinkered with it last night and seems to be better. I'll keep checking on it and see what happens.
ford4wd08
513
Alcoa, TN
2.8 V6
Reviving one of my old threads for a question.
I don't have the carb on B2 that I had so much trouble out of, I now a non feedback 2150 from a pinto.
So, here is my question. I have the carb set up well via a vacuum gage. It runs great, doesn't seem to have any real issues.
The only time I have any issue is on a cold start. I pump to accelerator a few times, and it fires right off, runs for about 10-15 seconds, then dies. Have to pump it some more then it will run take off and run then. Is that sort of normal?
And the only other problem I have if hasn't run for a few minutes on a cold start is I have a dead hesitation in the throttle. It only happens if I come to a stop after running for a min or two before it is warm and then try to take off.
Once it is warm, no issues at all. Any suggestions? I believe I have the V notch and all the pull off set correctly.
@Uncle Gump @RonD @19Walt93
