- Dec 26, 2017
- Above the equator
I'll deal w/the trunk & GC cylinders in the future.
Did an oil change on the '97, of course I dropped the oil filter pliers in the drain pan before the filter was able to be taken off by hand...
I’m pretty sure that’s supposed to happen. I do it on a regular basis.
Please clue me in on what you're talking about there...Got these NOS touch halos on the way.
Part of a courtesy light system. Keyhole lights up momentarily when bezel area is touched. I should be able to tie it in to my dome light as well.I know the '99 Ranger has a dead battery and needs at least a little attention to the brake system. First step is to get working on it is making it start and run. So broke out the weedeater, cleaned up around the truck and hooked up the battery charger.
Way it acted I'm not confident the battery is still good, charged for a couple of minutes then switched to maintain mode. Manually set it to the 2 amp charge mode and letting it charge overnight, I'll see how that faired tomorrow.
Even if the battery is bad now, it still had a drain prior, so I'll try to isolate what is causing causing it and at least get that disconnected this week. Once I've got it running, I'll get started diagnosing the brakes, maybe next week of something else doesn't need my attention instead.
Junk yard.What did I do to my Ranger? I picked it up from the mechanic. The upper intake manifold is warped, and the mechanic can't find a new one. So, I had to pick it up until I can find a replacement. I'm also having an issue with finding the gasket. Anyone have any tips?
Good point. I have a 2004 Ranger 3.0. My mechanic tried the junk yards with no luck. The ones he was sent were wrong. I checked RockAuto and Summit. They don't have them. No luck with Carsparts.com. I found one on eBay, but I'm hate buying used car parts. There's always a high chance of getting a bogus part.Junk yard.
Carparts.com
Ask around here in case anyone has one. But more details will be needed. Year, what engine, might need to know if it's california or not or flex fuel. Where are you located? I would think the gaskets should be available. Did you look on RockAuto?
